Thread: Help with main drain cover
    Jul 2013
    Philly
    82
    Okay so my new to me pool (bought new house that has ig pool) has no cover over the main drain. So i am going to be installing an sdx retro cover. Now the part i need help with, id rather not have tl drill into the concrete to put plastic anchors to secure the trim ring part down. So my main drain sump is 5 3/8" diameter and the part that looks to me where i can put screws into is 5 1/8" diameter. My question is, can i screw into these parts though as there is no hole there at all. Pics in next post. You can see on the left and right side there is little bumped out spots. But i dont wanna screw thru into them if they are not solid and then have a leak.
    23k gal, ig concrete pool, Plaster with Quartz finish, V.S. Intelliflo Pentair Pump, Pentair 36 sq ft de filter, hayward 350k btu gas heater, Dolphin DX5 Plus, TF-100 test kit w/ speed stir
    Philadelphia, PA.... anthony & sylvan pool!!
    Jul 2013
    Philly
    82
    Re: Help with main drain cover
    Jul 2013
    Philly
    82
    Dont mind the chipped up rock around the drain as it was fixed after this pic. And the copper pipe sticking out is there simce the pool is empty and the plug is pulled. So i stuck that in there to keep it open for pressure but pritect the threads at the same time.
