Results 1 to 7 of 7
Thread: algaecide 60, best price?
    26500 gallon vinyl above ground, bleach & boric acid.
    All chemicals are within troublefreepools.com guidelines and the water is stunning.
    I use algaecide 60 in my pool and the cost of $24 per quart online or $30 at the pool store is killing me. Any suggestions for a better price online or an alternative product?
    Algaecide 60 is the only chemical that I use routinely that troublefreepools.com has not slashed the annual cost.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: algaecide 60, best price?
    We can slash your cost on that too cause we generally don't even recommend the use of Algaecides! Not required if you maintain pool chemistry properly.
    You are kidding me! You should shout that one from the rooftops.
    Donldson's Avatar
    NW Ohio
    2,917
    You only need algaecide if you intend to lower your FC below intended levels, such as when treating metal stains. I have not used an algaecide in several years, not even to close my pool.
    You are right though, let's take it to the roofs! Somebody pop "Any Way You Want It" in to the CD player!!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    I am dancing to the tune of $175-$200 savings per year.
    Jun 2012
    Howell, NJ
    977
    Quote Originally Posted by Donldson
    Here you go. At least you didn't say Don't Stop Believin'. Every time I hear that song it gets stuck in my head and tortures me for the rest of the day.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Butterfly's Avatar
    South Carolina
    10,045
    Another happy TFP member
    and thanks to the responders
    You're done SLAMing when:
