Results 1 to 8 of 8
Thread: Ignorant of my own pool equipment - circulation issue
    Jul 2011
    Indianapolis
    63
    I'm having circulation issues, and I suspect something in my pump equipment, but I'm not smart enough to even tell you what it is. First, the problem: I have eight wall returns and three in-floor cleaning jets, and typically the returns would fire two at a time, rotating around the pool, and the floor cleaners would pop up one after the other. Recently, I've noticed that only two returns are working, and they're on all the time; likewise, only one floor jet pops up and it stays popped up all the time.
    I have this in my pumping station:
    The top looks like this (the pressure gauge has always read low, but right now it's very low):
    Is it correct to assume that attacking this would be the first step in troubleshooting my circulation issue? If so, can anyone give me some instructions on what I'm going to find when I take it apart?
    Notes: Filter pressure is good; brand-new pump motor (AO Smith 1hp) although this issue was around right before the old pump motor died.
    19000 gallon IG installed in 2003, owned by me since 2010, vinyl liner, 18x36, Sta-Rite PLM-150 cartridge filter, 1hp AOSmith motor on <brand unknown> pump, automatic cover, BBB since August 2011
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Ignorant of my own pool equipment - circulation issue
    Unless your filter pressure has dropped, the valve pictured is the place to start.
    Jul 2011
    Indianapolis
    63
    Thank you. Is there anything I should be looking for once inside the unit? All the gears seem to move freely, but I have no idea what else to look for.
    Jul 2011
    Indianapolis
    63
    Please? Anyone? Or should I just call someone out?
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    I am always amazed at the variety of equipment used on pools. I have never seen this kind of thing before. However, I did find a manual on line for something that looks just like your valve and the manual contains some troubleshooting tips. It might give you the answers you need. Note that the manual appears to just be scanned in and the pages numbers jump all over.
    http://lib.store.yahoo.net/lib/yhst-.../paramount.pdf
    Hope this helps,
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    30,419
    Few people on here have experience with in-floor systems....it may be difficult to get help.
    Jul 2011
    Indianapolis
    63
    Thanks Dave, that makes sense. Would you or the other experts here consider just capping the system off and having a more "standard" pool circulation system?
    SW Indiana
    9,199
    Quote Originally Posted by MLock
    A lot of people do that, but I wouldn't give up without making an effort at repair. It isn't rocket science, and as long as you can keep it working without excessive costs, you might as well.
