Thread: Electrical problem
    gregg4565's Avatar
    Jul 2013
    Tucson AZ
    12
    Electrical problem
    So here is my problem, i installed a new pump on saturday. No problems doing the wiring,primed the pump and it warunningreat.I had to add some salt and wanted to run the pump for 24 hrs to get it all dilluted. I went to bed round 8pm pump was running fine, got up at 3am for work and the pump was off and the breaker was trippedoff. Reset the breaker and turned on pump and tripped again. At that point i left it off and had to get to work. I know i cant do anything till later today but hoping for some advise.could bre a loose wire could be a bad breaker.
    11,000 gallons
    in-ground
    Hayward sand filter
    1 hp hayward energy flo rs
    Built in 2000 (aprox)
    Swim pure plus SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Electrical problem
    What size is the breaker, and is it a GFCI? Is the new pump the same as the old one?
    Jun 2012
    western NY
    1,559
    Is the pump the only thing on this circuit? When you restarted the pump, did the pump run before the breaker tripped the last time? Could be a white vibrated loose while it was running.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    gregg4565's Avatar
    Jul 2013
    Tucson AZ
    12
    The breaker is a 30 amp.. the pump is a 1 hp just likr the old one.
    Yes only pool pump on this line. It was only the breaker at the pool box not at the main panel
    11,000 gallons
    in-ground
    Hayward sand filter
    Swim pure plus SWG
    gregg4565's Avatar
    Jul 2013
    Tucson AZ
    12
    the problem was a bad capacitor. leslies replaced the capacitor and running fine.
    11,000 gallons
    in-ground
    Hayward sand filter
    Swim pure plus SWG
