Results 1 to 7 of 7
Thread: Greetings from Western MA.
    Bought a house three years ago with an existing pool,not sure of it`s age but was glad it came with the house.
    This year we waited until last Saturday to open due to a new deck being built and was greeted by a 24` above ground putting green,needless to say I dropped a good chunk of change at the local pool supplier with less than satisfactory results.
    In my search for answers I came upon this site and quickly signed up hoping to snoop around and learn.
    Thanks in advance for whatever information I may find and use.
    Jim S Chicopee MA.
    24` AG 15,000 gals
    Hayward CC1500 150 sq ft. cartridge filter 120 gpm
    1 hp single speed motor connected to Hayward mod # SP15921 LFP pump.
    30,414
    Re: Greetings from Western MA.
    Hi, Jim. Welcome to the forum.
    I always suggest newbies start in Pool School and read "The ABC's of Pool Water Chemistry". Get a good grasp on that info as it is the basic stuff you need to know to manage your pool.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Make sure you attend pool school and take all the coruses. You will want to arm yourself with one of the reccommended test kits. Best invest you can make. It will make maintaining your pool alot easier.
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    Because you donated to support the site before your first post, it is obvious that you realize you have found the premier pool care site on the net
    Folks here will help you take control of your pool and enjoy doing it.
    You're done SLAMing when:
    Mar 2011
    Grand Rapids, Michigan
    279
    Welcome, Sirjames41! I also spent way too much money at the PS without good results. You have come to the right place. Do get one of the recommened kits ASAP. Lots of us use the TF100 along with the Speedstir. I spent less on the kit and Speedstir than on one trip to the PS for the "free" test that indicated what and how many expensive things I needed to buy. Read, read, read and read somemore! Your pool will turn into the oasis you want it to be and you will learn how to do it without the pool store"s hand in your pocket. Better yet, you will get the results you are looking for--a clear pool!
    Since following TFP and doing things the right way, I can tell you that I have not had to SLAM my pool once or use algaecide in the last three years. It's all about keeping the water balanced the BBB way. With a green pool now you are going to receive lots of info on SLAMing your pool. Listen to it and follow their advice and you will get there.
    Almost forgot! Thanks for supporting this site.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Quote Originally Posted by Butterfly
    Compared to what I spent at said store the fee for this site was practically free.
    24` AG 15,000 gals
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum and thanks for your support!
