Results 1 to 7 of 7
Thread: What am I doing wrong
    May 2013
    Cyprus
    159
    Am I so thick I cannot get rid of algy, Yesterday my chlorine was 3 this morning my chlorine was .5 and a thin sheen of green algy in my pool. It has been just 5 days since I got rid of the last lot. My TA is 110 my pH is 7.8. I know you are going to ask for my tya but as yet I have not the test kit and cannot get one until I get a visit from the uk. The post here is at best unreliable and only bills get through this is not an exaggeration.
    HELP a wrinkly day.
    Living in Cyprus
    Still enjoying life
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What am I doing wrong
    Ok, if you don't know your CYA levels this can be very hard to do as you will be guessing on correct FC levels to clear the algae and more important on what the correct level is to maintain it once cleared.
    We can take some educated guesses about the situation, but we need some more information,
    Do, you know when was the pool last refilled with water?
    What have you been using for chlorination (bleach / liquid chlorine, dichlor, trichlor, Cal-Hypo ?) About how much of each?
    How much water splash out / overflow do you have, as well as replacement from rain fall?
    Ike
    p.s. without a detailed test kit how do you know you killed off all the last batch of algae, and did not just kill 99% to get it below the visual detection level, then let it bloom again when you lowered chlorine level
    May 2013
    Cyprus
    159
    The pool was filled 18 months ago
    I am using Trichloroisocyanuric acid ,TCCA 90 I will have to translate the rest of the information as it is in Turkish.
    I use about 5 tons of well water a week which has a hardness of 500. Their is no rainfall in the summer here from June to December.
    Living in Cyprus
    Still enjoying life
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sound like you have a classic case of over stabilization, of course without test results it is hard to tell just how high the CYA level is. And as you likely know by now the only solution is substantial water replacement, but again without test results it is hard to say how much. On a side point have you at least switched away form using the trichlor that is the root of the problem?
    May 2013
    Cyprus
    159
    Hello Isaac-1
    is trichlor Trichloroisocyanuric acid.
    Thanks
    Living in Cyprus
    Still enjoying life
    38,301
    Yes. And the cyanuric acid in the name is the stabilizer / CYA.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes it also goes by several other names, take a look at this link for a few (right hand column, other names)
    http://en.wikipedia.org/wiki/Trichloroisocyanuric_acid
