Results 1 to 10 of 10
Thread: Acid
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Acid
    I need to lower my pH (it is reading at 7.8)
    Is hydrochloric acid the same thing as muriatic acid?
    4600 gallons, Intex Ultra Metal Frame 14' round 4' depth, SWG, cartridge filter pump, 2500 gph, Pool finish date: 7/16/13.
    Re: Acid
    Yes, they are the same.
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Re: Acid
    Thank you! I went to Home Depot to buy muriatic acid and came home and noticed it said hydrochloric acid. Thought I goofed.
    Thanks again!
    Re: Acid
    Note that there are two different strengths. 31.45 % is the full strength and usually the better deal.
    When using the pool calculator, it's important to select the strength you are using.
    calc.html
    Support the site
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Re: Acid
    I checked and have the 31.45% strength. I will double check before adding.
    Guest
    Re: Acid
    Somewhat related question.. Where in Home Depot do they keep the muriatic acid?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Acid
    Quote Originally Posted by Pool School
    Muriatic acid is sold by most hardware stores and some paint stores. The big box hardware stores, like Home Depot and Lowes, almost always have it, but they seem to put it in different departments from store to store. Sometimes it is outside in the garden department, sometimes in pool supplies, and sometimes in the paint department.
    You're done SLAMing when:
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Re: Acid
    I finally had to ask someone where it was. It was in Outside Garden and was as far away from everything as possible. It came in a cardboard box (2 per box).
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Acid
    Quote Originally Posted by itodd
    Yep, BTDT. They sure like to keep things moving around
    Is it the 31.45% ?
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    Re: Acid
    Quote Originally Posted by Butterfly
    Is it the 31.45% ?
    It was the 31.45%.
