Results 1 to 10 of 10
Thread: Adding muriatic acid
    Hi,
    I am new to pools so I went to my pool experts and they told me to add muriatic acid to my water. They told me to add the acid to the pool and leave the pump off for at least 4hrs. I read several posts that say to leave the pump on to circulate the water. This seems more logical. What is the proper method for adding the acid.
    Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Adding muriatic acid
    They have recommended that you acid becuase your PH level it too high. Got any numbers to post? We recommend PH around 7.5. Pour it in front of an upturned return nozzle (slowly) and allow the pool to ciruclate for about 30 minutes. NO "pool experts" would recommend that you not circulate it. Welcome to the forum.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Yeah. Turn off circulation, pour in MA, have it gather and sit at the bottom before it SLOOOOOOWLY disperses itself. Great advice. Can't believe they actually told you that.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2012
    Howell, NJ
    977
    What type of pool do you have? If you have a vinyl liner, that is a sure way to ruin it. The acid would probably eat a hole right through. You want to leave the pump running at least 30 minutes after adding chemicals.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    I just purchased the pool from a large residential pool store. I took my water there to be tested and they gave me a sheet with the instructions that are as follows:
    1. Shut off pool pump and wait for water to settle.
    2. Add acid in pool at the opposite side of pool from skimmer.
    3. Leave pump off for min of 4-6 hrs.
    4. Turn pump on for at least 6 hrs.
    5. Retest.
    My numbers are:
    FC: 8.8
    pH: 7.4
    Total alkalinity: 180
    Calcium: 175
    Stabilizer: 15
    Thanks
    30,419
    7.4 is perfect for pH. Are you sure this was a pool store and not a pool hall?
    Definitely leave the pump on. Their method is based on an old discredited myth.
    http://www.poolhelp.com/handouts/oB_Aci ... andout.pdf
    Their concern was probably the TA. Here is the proper way to lower the TA.
    pool-school/lowering%20total%20alkalinity
    Support the site
    Donldson's Avatar
    NW Ohio
    2,893
    I believe they are trying to reduce his alkalinity. It sounds like the same idea as an acid slug, and just as likely to cause liner damage.
    Er, yeah, what James said
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Welcome!
    You have done well to find us and ask before making all the stupid mistakes the professionals would have you do.
    Where'd you get those test results? Who makes a CYA test that reads to 15? It wasn't test strips, was it?
    A few hours spent in Pool School and a few bucks on a decent test kit, and you are set to have a trouble free pool, with water that sparkles so much you'll be the envy of the neighborhood.
    Jul 2011
    844
    LOL. Good one!!
    Bestway SWG
