Results 1 to 16 of 16
Thread: started conversion then torrential rain, now what
    Jun 2008
    Sun Prairie, Wisconsin
    11
    Hi, I live in WI, as you may have seen on the national news we have had torrential downpours (about 10 inches in less than 48 hours). I had started conversion about 3 days before the rain and had the pool overnight once at 15ppm. Then the rains, had to drop the level of water twice and of course, no chlorine left after that, now what? Do we start over? We have a 27' round ag pool with a sand filter. Thanks for your help.
    ~Nikki
    27' ag pool with 100lb sand filter.
    I'm a big fan of . . . swimming of course . . . with a book . . . and a glass of wine . . . or a micro beer . . .
    Jul 2007
    Northern NJ
    299
    Glad you and your family are well.
    Yes, start over. Having to lower the water level may have worked to your advantage since you were essentially replacing water and therefore lowering the baq levels as well.
    Just get a full set of numbers so you know what you are starting with and then start adding the bleach.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Jun 2008
    11
    so then, do I need to keep at 15ppm for 48 hours or is it good enough to make it overnight then I can adjust everything else.
    Bring FC back up to 15 this evening and test again in the morning. If the FC level remains the same overnight and the CC level is below 5 you are good to replace the filter media and then start adding CYA.
    Jun 2008
    11
    Thank you very much. I am so hoping to have the pool ready for swimming by this weekend since school gets out on Friday. This is a great forum and very helpful. I am thrilled with all the advice and tidbits I have been able to glean. I "freecycled" what little bit of baqua stuff I had left after last season (and felt sorry for the lady who took it!) You guys offer a great service, thank you again. I will post my numbers tomorrow morning so keep your fingers crossed!
    ~Nikki
    Jun 2008
    11
    Re: started conversion then torrential rain, now what
    Well, I've kept it at 15 all day, I am going to make sure it is still 15 tonight and check it tomorrow, if it is still 15 then we will have done three days in a row. Hopefully that should be enough to be switched over. What do you think?
    ~Nikki
    30,432
    What do you think?
    The process is complete when:
    A. You hold FC loss to 1.0 or less overnite
    B. Your CC's test .5 or less
    C. Your water is sparkling
    Jun 2008
    11
    okey dokey. I can test the TC and the FC but I have no way to test the CC. However, if I test both of those and find the difference it should be CC, correct? And for some reason I just don't see the sparkly, but maybe that's just me. The water looks good, I can see the bottom but my liner is blue so it is hard to see sparkly. Maybe sparkly isn't here yet, what exactly is sparkly in an ag pool with a blue liner? Help me out here, I need a definition for sparkly!!
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    I can help with sparkley since I recently converted....sparkley is what you used to get when you added a bunch of floc to the filter and got rid of the baqua-haze for 12 hours. You can see the "sun lines" on the bottom of the pool at 8 am. Your neighbors and significant other remark that your pool looks like a jewel. You get in with goggles and say "OMG...I have NEVER seen my pool this clear!" Your blue liner looks DEEP BLUE...you will know it when you see it, believe me.
    And yes, your calculation for TC = CC + FC is correct.
    HTH.
    Jim
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    Jun 2008
    11
    Well no wonder I can't see sparkley!!! We live in WI where it has been raining cats and dogs and the sun is just a distant memory. I have to drain the pool down again but my levels kept overnight!
    ~Nikki
    Jun 2008
    11
    OMG!!! The sun is peeking out and is reflecting off our pool through our kitchen window onto the soffitt above the fridge . . . if that isn't sparkley then what is!!! And there it goes, well it was brief but beautiful while it lasted . . . no more rain . . . no more rain . . . no more rain . . . say it with me . . .
    ~Nikki
    Jun 2008
    11
    I have a new situation. My pool numbers were great, sparkleyness was achieved-all was well in pooldom. So, we put the solar cover on so we can warm the water for swimming. Now, the cc's are high again. The FC are still holding overnight. I have come to the conclusion that the chlorine is having to clean the cover because it was last on a baquacil pool. Do you think this can be correct? What do I do now, do I need to reshock the whole pool once it eats everything on the cover?
    ~Nikki
    Sunlight helps keep the CC level down. Remove the solar cover and maintain proper FC levels and the CC level will go down. Or you can shock if you want. This will ease up when the last of the baq goo gets burned out in a few weeks.
    Jun 2008
    11
    By proper levels do you mean swimming levels or 15ppm?
    ~Nikki
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I think he means your normal target of Free Chlorine, 15Ppm sounds like shock level. If you leave the cover off, and let the sun break down the cc's you won't need to shock. Or you can shock instead.
    Hope that makes sense?
    Jun 2008
    11
    Well, the pool is beautiful. My son had a birthday pool party yesterday in our sparkling pool. Great fun was had by all. I can't thank you all enough for your help in the conversion process. We couldn't have done it without you! Now if only the water would warm up faster! (80 isn't warm enough for me!)
    ~Nikki
