Thread: The Circulator or SwingJets
    fox_and_hound's Avatar
    Jun 2013
    Sunny Florida
    79
    I am debating between "The Circulator" or "The SwingJet" for added flow, increased circulation, and good surface movement.
    Someone said the circulator requires layers of scotch tape to secure it. I emailed the company, they said indeed scotch tape is part of the install. That seems kinda weird to me. Any ideas on that?
    Also, I cant find a price on the SwingJets. They appear to be built better (no tape is needed), but they only rotate 90 degrees, the circulator seems to rotate 180 or more.
    Thanks so much!
    28k IG with Spa, hayward Super 2hp pump,
    120BTU Heater, Pentair PXC125 cartridge filter
    Love my Dogs, Maintain a Reef Tank, Foodie :)
    Re: The Circulator or SwingJets
    There is no point in getting anything of that kind if you are willing to spend a few minutes adjusting a standard return eyeball fitting appropriately. A properly aimed standard eyeball fitting will give you near ideal circulation, mixing, and surface flow.
    Jun 2013
    Sunny Florida
    79
    Thanks! So, how should they be pointed and what size opening is ideal (larger or smaller eyeball)?
    Should they be pointed upwards at the surface, but in a position that doesn't create bubbles?
    Or should the be pointed upwards, but each one oriented so flow is clockwise to the skimmer?
    Jun 2013
    Sunny Florida
    79
    You were right. I adjusted the normal pool eyeball fittings and they are great! Thanks for everything!!!
