Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Lost confused crying pulling hair out delimas delimas
    Kannapolis, NC
    89
    Soooooooooooooo the drama continues!!!!!!!!! And I thought it was over. Here is my problem, I have been running the pool the last few days, while in the cleanin a green pool process with out adding much chlorine. I for the most part had given up again but waled out by the pool it was blue no green at all, I was stoked. So I went to Ollies and bought some bleach and decided to throw the bleach in to get the cloudiness to go away. Thirty minutes later I have a green pool again. What gives???? My numbers are fine so dont ask that question. I am thinking this is an equipment problem. As during the days that I was letting the pool run I had it pulling from the main drain as well as the skimmer. After putting in the bleach I went full skimmer to get a few things off the top and green green green. Did I say green. So what gives???
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lost confused crying pulling hair out delimas delimas
    You prop didn't maintain shock level long enough. You need chlorine to clear a pool.
    Read the SLAM process.
    What are your test results and what kit are you using ?
    Your done when
    1 you pass the OCLT test
    2 CC of 0.5 or less.
    3 water is clear.
    Jeff
    Kannapolis, NC
    89
    I know all you just mentioned, I maintained and no I didn'tgo clear not even close but I did go blue and no hint of green and the 30 minutes after shocking again back to green.
    _________________
    My Pool:
    38,521
    You know we like data ... post the test results.
    Adding bleach causing the pool to turn green sounds like it could be metals in the water. Although they usually result in a clear color ... not cloudy as you state. So could be a combination of something causing the cloudiness and metals in the water.
    Problem is the way to treat them each are counter productive. Usually you want to get the pool clear and finish the SLAM process and then deal with the metal by adding a sequestrant and maybe doing an ascorbic acid treatment if you have stains.
    You could try adding some of the sequestrant as described here and then continue to SLAM to see if the water stays blue:
    pool-school/metal%20stains
    As pwrstrk said, I am not sure you are SLAMing properly.
    Donldson's Avatar
    NW Ohio
    2,917
    Quote Originally Posted by Bowlin
    Good news, we never ask if your numbers are fine. We say post them and let us see how "fine" they are.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Since the chemistry is fine, you must have annoyed this guy. I can't help you; I'm afraid to even try, lest he curse my pool, too.
    Kannapolis, NC
    89
    I use to value these opinions, but its agravating hearing I dont know what I am doing. My cya is non existent so I am shocking around a 12 ppm. My alk is 80 my ph is 7.5, my chlorine is 15 but going to check that in a few and up it back to at least 12 again so shock level yeah and maintain umm yeah again. Again my problem is not my stupidity but the fact that the water an hour agao was blue and after adding bleach its green again. Was blue with a chlorine reading of 0 thats zero so that why I went back to slamming and maintaining just to try and beat the cloudiness. But now I am being told I dont know what I am doing.
    _________________
    My Pool:
    Kannapolis, NC
    89
    Boogey Man
    _________________
    My Pool:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I don't think anybody said you don't know what you are doing. Just trying to find things out.
    Jeff
    38,521
    How non-existant is the CYA ... you should have it around 20-30ppm for the SLAM process, not only does it protect the FC from the sun, but it also buffers it so as to not be as harsh on the pool.
    With 0ppm CYA and 12ppm FC ... that is very harsh and could be a contributing factor to the green tint (is it a tint?) if there are metals.
    We have people all the time some here and say everything is fine in THEIR or a pool store's opinion ... that does not mean WE think it is fine. You could have easily checked your attitude at the door and just posted the numbers in your first post like you KNEW we were going to ask about.
    Good luck.
    Kannapolis, NC
    89
    How to test for metals?
    _________________
    My Pool:
    Jul 2013
    Southern Delaware
    71
    Why are you not keeping any CYA in the pool?
    13500 Gal. Above Ground. Vinyl. Hayward E-100 Highrate Sand Filter with Hayward Power Flow LX pump. Installed 2006.
    Kannapolis, NC
    89
    I have put cya in via bags and pucks numerous times. Severe, fast acting, chlorine demand is most often caused by ammonia left over form the degradation of cyanuric acid (stabilizer) by bacteria. This can occur if the pool is 'slimed' for an extended period of time. Slower acting causes can be dead algae, cheap algaecides, and more.
    _________________
    My Pool:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    You will either need to take a sample to a pool store that will test copper and iron or purchase those specific tests from an online retailer. Most stores do not keep those tests in stock for retail sales.
    Love TFP? Become a
    TFP Supporter!
    Kannapolis, NC
    89
    ThePoolForum here I come
    _________________
    My Pool:
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    Donldson's Avatar
    NW Ohio
    2,917
    No, stop, don't go, where else will we get our information on "slimed pools"? I need to know more about this bacterial degradation of CYA in perfectly balanced pools!!
    Northeast PA
    29
    Lol
    AG Pool 15 ft. round 4,000 gal. 100LB Hayward Sand Filter
    TF 100 Test Kit
    Carpe Diem!
    Jul 2013
    Southern Delaware
    71
    Find a wastewater plant near you that has a working lab, and have them check your ammonia levels...
  20. Back To Top    #20
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    That's funny, I'm a member there (poolforum/poolsolutions) as well.......
