Thread: Chemical Storage
    May 2013
    Tulsa, OK
    83
    Chemical Storage
    So where do people store there chemicals. I'm looking at a metal storage cabinet (like in an office) on my porch. Its shaded but would still get very hot here in Oklahoma. I have a shed in my back yard but I cant see it being any better then the cabinet on the porch. Any comments/ thoughts/ suggetstions..?
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    38,239
    Re: Chemical Storage
    The acid fumes will corrode that metal in no time. Better to look for a plastic deck box or something.
    Bleach and test kit should be stored out of the heat like an interior closet
    May 2013
    Tulsa, OK
    83
    Didn't think of think of the acid fumes. Hmm were to convince the wife to let me store all the bleach.
    Butterfly's Avatar
    South Carolina
    10,045
    It is ideal to store bleach inside; however, many of us have used our garages or outbuilding for ages.
    The MA should be stored away/separate from any chlorine source. Chlorine and MA do NOT play well together.
    Example: we store bleach (only a week or two supply) in the garage. MA we store under the deck behind a brick pillar and it is 'outside'. It is exposed to heat, but not direct sun.
    Others will chime in with their storage ideas.
    You're done SLAMing when:
    38,239
    I do not even think the sun matters for the muriatic acid ... beside the heating and probably more out-gassing as a result, but chemically I did not think it affected it.
    We keep the bleach in the laundry room (although much less now that the SWG is running) and the acid sitting outside by the pool equipment.
    May 2013
    Tulsa, OK
    83
    I'll have to use my shed for acid and garage for bleach. I can't leave anything remotely unlocked. My littler dependents will destroy and open anything not bolted down.
