Results 1 to 8 of 8
Thread: Safe to backwash into the lawn?
    May 2008
    Central Texas
    60
    Curious if it's safe to backwash into my lawn? I'm running about a 10ppm FC level. It's just so dry down here in Austin lately and I don't want to waste any water... of course, I don't want to kill any grass either!
    I'm using liquid bleach for chlorine.
    11,000gal, in-ground, concrete, sand filter, 3/4 HP pump, TF-100 Test Kit, Austin Texas
    Maybe take a small sample of water and saturate an obscure section of the grass to see if it has any ill effect?
    Yes, pool water is fine except for the most chemical sensitive plants.
    May 2008
    Central Texas
    60
    My yellowing lawn thanks you.
    I have no issues.. however, my polaris got stock against the ladder and the tail sprayed water (for what I assume was a few hours) and killed my wife's tulips.
    2003 Marquis Euphoria - 400gal
    If you add salt to your water for feel or SWG then you can burn/kill the grass.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Most kinds of grass are just fine with water from a SWG pool. There are many plants that are not bothered by the salt level from a SWG pool. If you are in an area that gets very little rainfall, the salt can build up in the soil and you may need to limit swimming pool water use to salt tolerant plants.
    krcossin's Avatar
    Detroit Burbs
    113
    Re: Safe to backwash into the lawn?
    Backwashing your DE filter to your lawn will kill grubs!
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
