Thread: Spa drain leak
    Spa drain leak
    I have a leak in one of my two spa drains. After completely draining my spa, I plugged each drain and found that one was draining down to the level of the plastic. After refilling the drain to the bottom of the spa, I used dye and found the leak to be where the gunite met the plastic. What would be the best way to repair this leak, short of breaking up the concrete?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Spa drain leak
    you can use a bunch of stuff. A-B Putty, Butyl Tape, Anderson Flex sealer, Plast-aid. A-B Putty might be your best bet. You can get some at your local hardware store.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
