Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: everything tests okay but water a bit cloudy
    Jun 2012
    Michigan
    154
    I just tested chlorine and bromine, pH, total alkalinity, total hardness, and cyanuric acid and everything was in the recommended range. the water seems just a tad cloudy still though. any thoughts on what might be causing it. the last time the filter was replaced it wasnt rinsed firstI don't know if its just that or how to fix that. this is a 16x48 above ground pool from intex
    Intex 16x48 UltraFrame AGP, included filter pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: everything tests okay but water a bit cloudy
    Why are you using bromine?
    Bring it back to shock level. I had the exact same problem this year. It was clear the next AM. I didn't want to, but I used 2 bags of super chlorinating powder (shock). It brought it up to level and cleared out the cloud. You could also use bleach. I just had the stuff from years past and used it.
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Apr 2010
    East Texas
    9,643
    Bromine can't be stabilized against sunlight, so it is not a good choice for outdoor pools. It isn't impossible to use it outdoors, but you will lose a great deal of active bromine to sunlight, meaning higher chemical costs overall.
    Just found that in an older post by Jason Lion. FYI
    Jun 2012
    Michigan
    154
    No not using bromine, but that's what the test was called which really just checked for chlorine for me I guess. guess I can try shocking it
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I am assuming that you have the HTH 6-way test kit.
    You can get the FAS-DPD test reagents separately, from http://tftestkits.net/
    For SLAMing your pool, read in pool school, linked in upper right of every page. The FAS-DPD is a must for clearing cloudy/green water, as it is able to test much higher and more accurately than the OTO kits.
    What were the test results you mentioned?
    Also, could you put your pool and test kit info into your signature? It would help us to help you. Sig line can be edited through the user control panel, linked in upper left corner.
    Jun 2012
    Michigan
    154
    yes I do have 6 way kit you mentioned. I'll check out the link you sent me. I don't remember the exact numbers by know chlorine and pH were great, the others were on the lower end of the recommended scale if I remember correctly
    Donldson's Avatar
    NW Ohio
    2,916
    The same OTO test tests both chlorine and bromine. It gets confusing when people mention bromine if they are not using it, so just make sure you call it the chlorine test next time.
    Who's recommended ranges are we talking, TFP ranges or another source? If you could post the actual results that would be helpful.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Honestly, if you can afford to, you should get the TF-100, with XL option and SpeedStir. Guaranteed you will love the kit!
    In the mean time, you could test again, mainly the TC and pH, but a full set of numbers would be helpful. I understand the 6-way only has enough CYA reagent for a few tests, but that one will be key to clearing your pool. That will determine what your SLAM level needs to be.
    Jun 2012
    Michigan
    154
    I shocked it yesterday so the reading this morning for chlorine is in the three to six range for pH 7.2 for total alkalinity 60 and a total hardness of 140 which is lower than it was yesterday (was 200) not sure if that's because of the Shock or not.
    Donldson's Avatar
    NW Ohio
    2,916
    I think we help you get your water cleared. What is your CYA level? This is the most important piece of information before going forward, the number everything else will be based on.
    It sounds like you are doing a "traditional shock" where you just add a bunch of chlorine at once, am I correct? What source of chlorine are you using to shock? If it's a powder, what is the active ingredient listed on the front?
    Traditional shocking is usually inadequate to completely clear a pool, that is why the SLAM process was created. It is the best procedure to clearing everything out that can cause cloudiness and help to prevent future problems. Read up on it, it is a great help: pool-school/shocking_your_pool
    Jun 2012
    Michigan
    154
    Sorry forgot about cya, when i tested it yesterday it didn't even register on the test so had to be less than 30 (believe that the lowest number that test tells youfrom that kit).
    I used that hth shock the one with the blue label not the red
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Do you remember if it was dichloro or cal hypo?
    Jun 2012
    Michigan
    154
    I don't remember sorry
    Donldson's Avatar
    NW Ohio
    2,916
    HTH is cal-hypo, blue label is 48%, red is 53%.
    Jun 2012
    Michigan
    154
    so basically I need to do the slam thing to clear the water?
    Jun 2012
    Howell, NJ
    977
    Yes. Follow SLAM until 1) Your CC is <.5, 2) OCLT <1, and 3) your water is clear. Do you have the recommended test kit?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2012
    Michigan
    154
    the only test kit I have is the one I posted earlier
    Jun 2012
    Howell, NJ
    977
    Ok, I missed that part. That test kit is fine, except for missing the FAS-DPD test for chlorine. It will be impossible to know that you have met all 3 criteria for ending SLAM without it. You should consider ordering the FAS-DPD test, so you can make sure you pass all 3 criteria and will not have any more problems in the future.
    John
  20. Back To Top    #20
    Jun 2012
    Michigan
    154
    I wonder if this has more to do with my filter now that I look at it some more. it doesn't seem to be sucking water in like it should. by the lower valve I can hear the water almost but everything seems tight like it should be. I wonder if I need a new hose or connector valve thing that hangs outside the pool that the hose connects to.
