Thread: Filtering through Main Drain without skimming
    langerking's Avatar
    Jul 2013
    Clermont, Florida (that's near Disney World)
    104
    Since I need to dilute my CYA infested pool, I am draining down every day to below the skimmer and I am filtering through the main drain only. I am doing it gradually because I want to use rain water (I diverted one of my gutters) which has a pH of ~7.4 rather than my tap water (pH <6.8)
    Obviously the floating debris will just circle around but other than that does this prevent any problems to operate like this for maybe a week? How long before not skimming starts to cause any problems?
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    5) Hayward 1.5 hp DE 3600 72 GPM
    Taylor K-2006
    STA-RITE Great White GW9500
    Re: Filtering through Main Drain without skimming
    Mid-summer that should be fine for a week. You will get a little more debris settling to the bottom than you are used to, but it shouldn't be difficult to keep up with.
    langerking's Avatar
    Jul 2013
    104
    Well it is going to be a lot longer than 1 week if I rely exclusively on rain to fill my pool. We are just not getting significant rain amounts and the rains have been really short in duration as in 5 or 10 minutes. I only took the water level down about 8 inches and in 5 days it still hasn't filled up. Its irritating because earlier this month the pool was overfilling and required multiple pump outs. This was before I diverted water from one of my downspouts into my pool. I may have to revert to well water if I want to get this CYA diluted any time soon.
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    Taylor K-2006
    Jun 2013
    Huffman Tx
    190
    that's why they have pole skimmers
