Results 1 to 15 of 15
Thread: Help -Top Ring Vinyl cleaners?
    Jun 2013
    Manitoba, Canada
    153
    My 18' Intex top ring has some brownish substance on it (hardened) which will not wipe off. Any ideas on what eveyone uses to clean their top ring? It's not all around the ring, only in some areas. Does not seem like tree sap, not sticky, just hard crust. I have never had this before, and its our 3rd summer with the pool.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Top Ring cleaners?
    Try one of those Magic Erasers...amazing what they will do.
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    These are probably solid deposits, water splashing repeatedly on the ring evaporated leaving behind all dissolved solids, over time solid deposits became thick enough to be visible, mainly calcium with a bit of chloride bound to it.
    Most of these deposits can be removed with light scrubbing using some soft wet cloth material (not an abrasive sponge), the most difficult ones can be persuaded using a soft cloth soaked in vinegar.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Jun 2013
    Manitoba, Canada
    153
    Quote Originally Posted by woodyp
    Nope, didn't even touch it.
    Jun 2013
    Manitoba, Canada
    153
    Re: Top Ring Vinyl cleaners?
    I have also now tried vinigar, nope..........
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Re: Help -Top Ring Vinyl cleaners?
    Vinegar is a very "mild" acid, so it might take some time and effort, the objective being to see if the deposits are diluted by acid.
    Signs of dilution would be the cloth changing color, taking the color of the deposit.
    If vinegar does dilute the deposits, then let the soaked cloth on the deposits for some time and see if they come off then, after the vinegar had some time to act.
    Jun 2013
    Manitoba, Canada
    153
    Okay. I have soaked a cloth in vinegar nad have it laying on it for a bit. I will check it every 5 minutes to see whats happening.
    Jun 2013
    Manitoba, Canada
    153
    Nope, vinegar does not work. Left a cloth soaked all night on a spot, didn"t even fizz it.
    Jun 2013
    Manitoba, Canada
    153
    I bought some vinyl cleaner from the pool store called Amaze..........didn't amaze me, stains still there after scrubbing like the dickens.
    Any other suggestions?
    Goo Gone? I have good luck with that on things. Is the brown tacky? Could it be sunscreen - that leaves some nasty stains on my concrete.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jun 2013
    Manitoba, Canada
    153
    I have tried goof off, clorex wipes, citrus wipes, and even a little dab of acetone (whcih I quickly wiped and hose off)
    Nothing..............
    If it is just cosmetic, I wouldn't worry about it. If it is sticky though, that would bug me.
    Jun 2013
    Manitoba, Canada
    153
    Ended up that using chlorine and a lot of scubbing helps. Is not perfect, but looksa lot better than before.
    Apr 2016
    Adelaide,South Australia. Australia
    1
    Hi. I am in Australia and have exactly the same problem! I know this is an old thread so won't go into it but if anyone out there can assist or point me in the right direction that would be great.
    Jul 2014
    Oakbank, Canada
    389
    Nope, I ended up scrapping the pool and bought an Ultra one instead.
    Quote Originally Posted by Ashman View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
