Results 1 to 10 of 10
Thread: How to add DE to sand filter? - no skimmer
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    My skimmer is totally separate from my filter setup. How can I add DE to my sand filtef? Searched but could not find.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: How to add DE to sand filter - no skimmer
    Do you just have an intake hole for the pump in your pool? Do you connect any vacuum to your pump?
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    844
    No. here is a pic of my setup:
    well that didnt work. Hang on.
    Bestway SWG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: How to add DE to sand filter? - no skimmer
    So.....you're saying you have a separately powered skimmer that just sucks water in and puts it directly back into the pool?
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    I've never have seen that before. On the right side of the pic you can see the back of the skimmer. It looks like it has its own motor and it returns to the pool just a few feet to the left. Interesting.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2011
    844
    Yes that is exactly what it is. Its the pump/skimmer that came with the pool. works fine as a skimmer but not near enough pump or filter to keep an 8000 gallon pool clean.
    Bestway SWG
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    It is a skimmer / filter (sort of) / pump combination.
    For adding DE, the sand filter pump's leaf basket can be used, it will not be as easy, but it can be done.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Jul 2011
    844
    Quote Originally Posted by asxetos
    Ok. So would i turn off the valves, put some DE in the basket and fire it up again?
    Bestway SWG
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    This is the idea, maybe not adding all DE at once.
    Jul 2011
    844
    Ok. Thanks a lot. Will give that a shot.
    Bestway SWG
