Results 1 to 9 of 9
Thread: pH steady TA slowly rising
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    For the past two months, testing the TA every two weeks, I've noted a very slow but steady rise in the TA. Past three weeks of daily pH testing has shown steady at about 7.5
    When I filled/opened the pool, TA was 190, same as fill water. Lowered it using acid/aeration to ~100.
    Test this morning showed 160.
    I've had to add water several times, but no more than 2" at any one time.
    Fill water at filling showed 190, today's test shows 280. Problem at the water plant?
    I'm guessing that I've answered my own question as to why the TA is rising, but that doesn't answer why the pH would be rock steady through this.
    30,432
    Re: pH steady TA slowly rising
    Well, it's a good problem to have, right? (Charlie, I think you're becoming a pool snob like many of us )
    My first inclination is to test the pH of your fill water......I don't think that'll be the answer but it's worth knowing.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That is strange. Can't wait to see what the experts come up with. You would think with the high TA the PH would rise also.
    Jeff
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Oops, forgot to add that in the OP. Fill pH was 7.8, today 8.0++ much darker red than 8.0
    Me? A pool snob? Possible, and maybe likely. Product of being a perfectionist, I guess.......
    30,432
    Your not chlorinating with pucks, correct?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I only used pucks for the initial CYA. Pool has been using a 121 oz bottle of 8.25% about every two weeks. Holding fairly steady between 4.5 (lowest I'll let it go) and 6.5 an hour after dosing
    CYA at ~35 (1/3 above 40, guestimating the log scale).
    30,432
    Well, that certainly is a puzzle. About the only things that drive down pH in a pool are pucks or low pH fill water.
    I sure don't have an answer but a lot of folks (me included) would gladly trade their pool water for yours.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    4800 gal wouldn't even raise your level 1", now would it?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    This may sound a bit odd, but I wonder if anyone else has experienced this.
    for several days before my normal full test day, the pool water was giving off an odor I've always associated with public pools. Not the chloramine odor, the "something's not right" old pool water smell. Hard to describe. At most, I've had .5 CC this year, and I know what chloramines smell like.
    Now that I have the TA back down to 100 with the aerate/acid routine --shooting for 80-- the smell is gone.
    I could only smell it while in the water, with my nose just above the surface.
    Test results this morning:
    FC 4.0 (lowest I'll let it get)
    CC 0.0
    pH 7.8 before another dose of MA
    TA 100
    CH didn't test
    CYA didn't test -- ~35 last test
    pH 1 hour after dose 7.0, still with the aerator going.
