Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Metal Staining on liner, steps. Having problems clearing up
    Jul 2013
    Nova Scotia, Canada
    17
    Hi everyone ... I've been reading all the posts about iron staining and how to fix. We've had our pool for about 7 years now and this is the first year we've had issues with it. This year, we had a small nick in our liner and, because we have salt water, it rusted before we could find it. It's since been patched, but oh what headaches trying to clear it up! Last Sunday night, I did an AA treatment (second one this year). Pool has been very cloudy since. I added about 1 litre of MetaSol by Pool Boss which is an HEDP sequestrant that same night. 24 hours later, I started adding 6% liquid bleach. I've added approx. 2 litres over the course of 5 days but no improvement and I can't seem to raise the chlorine level at all. Here are my latest readings: TC: 0, FC = 0, ph = 7.5, TA = 85, Calcium Hardness = 175, Stabilizer = 30, Salt = 3300. I have some non-chlorine product here (made by Tabex - Shock N Swim). Is it worth adding that? I know I'm supposed to bring the chlorine level back up slowly ... but how slow is slow? How much bleach can I safely add without getting the staining back? The local pool store keeps telling me to shock to get the cloudiness out of the water, but it hasn't been 2 weeks yet. I've also added polyquat to keep the algae at bay and I haven't had any this year. Should I try to get the chlorine up before getting the iron staining under control or do you have any other suggestions? Thanks in advance ... this is a great forum with lots of great reading!
    Leanne
    7300 gal, AG vinyl, sand filter, 1/2 HP pump, Intex SWG. Pool approx. 7 years old
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Metal Staining on liner, steps. Having problems clearin
    Welcome to tfp, lgayton
    Have you been following this procedure?: http://www.troublefreepool.com/ascor...ins-t2298.html You need to keep the ph down below 7.2. From that post, it says to not shock until the two weeks is up. You could supplement with a polyquat 60 algaecide.
    When did the pool turn cloudy?
    Jul 2013
    Nova Scotia, Canada
    17
    yes, I've been following the procedure as best as I can. The pool turned cloudy about 2 days after the first time we added the AA and has been that way ever since (2-3 weeks). I just added more metal sequestrant since we had to top up the water last night. I'll add more algaecide in the meantime. We're having a party in 10 days and it won't go over well if the pool still looks like this! Thanks!
    Butterfly's Avatar
    South Carolina
    10,045
    Is/was the only place you had staining on the steps?
    Yep, lower the pH back to about 7.2 and try to keep it close.
    How much AA did you add? You should continue to add about 2ppm FC until it starts to hold. FC has to cancel out the AA. Add FC and test/add again as often as every hour until it starts to hold.
    Have you tried adding some DE to the sand filter? Directions in Pool School.
    Welcome to the forum
    You're done SLAMing when:
    Jul 2013
    Nova Scotia, Canada
    17
    Thanks ... I thought I had some muriatic acid around but can't find it. Will go to the store tomorrow to pick some up. I haven't tried adding any de to the filter. And I can't get my hands in a good test kit locally so I've been running to the pool store constantly to have my water tested!
    Butterfly's Avatar
    South Carolina
    10,045
    Jul 2013
    Nova Scotia, Canada
    17
    No... it was on the liner as well. We tend to notice it on the steps first just because they're white and you can see it better. Last Sunday it was so bad the entire pool was yellowish brown.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by lgayton
    oh, okay. Had it only been the steps, I would have recommended another method for removing the stains.
    Jul 2013
    Nova Scotia, Canada
    17
    What about using some of the non-chlorine shock & swim product I have to try to clear it up? Its main ingredient is "Peroxymonosulfuric acid". Or will that have the same effect as adding shock?
    Thanks for your help!
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest you only use bleach/liquid chlorine to get the FC to about 2pm and maintain at 2ppm for now.
    Later, you can use the SWG to maintain once things are under control. You can also increase (later) CYA for the SWG recommended level.
    Jul 2013
    Nova Scotia, Canada
    17
    OK. I have been running the SWG in addition to adding liquid bleach.
    Jul 2013
    Nova Scotia, Canada
    17
    Hi - my latest readings: FC & TC = 0, ph now down to 6.9, Hardness = 130, TA = 20, CYA = 25. It's been suggested that I shock tonight after adding another dose of metal sequestrant. My chlorine levels have been this low for over 2 weeks now. What do you suggest? THanks in advance!
    Butterfly's Avatar
    South Carolina
    10,045
    You should add some baking soda and get the TA to about 70. Then retest the pH. Make sure the pH is at least 7ish (low 7's) and not in the 6's. Use borax if you need to raise pH.
    What does the water look like? I still suggest that you continue to add bleach/liquid chlorine to get the FC to about 2 or 3.
    I did not see a recommendation to shock, but maybe I missed it. Anyway, I don't recommend it! You want to s l o w l y raise the FC. Even if you have to dose/test it every hour or so, dose it slowly but continuously until it starts to hold.
    If you shock now, you might redeposit all the stains. We want to try to a void SLAMing the pool.
    Jul 2013
    Nova Scotia, Canada
    17
    So ... when you say to dose it every hour, how much liquid bleach would you add each time?
    Butterfly's Avatar
    South Carolina
    10,045
    Use the PoolCalculator to determine the dose. Link in my sig.
    If you have problems with figuring the dose, post back.
    Butterfly's Avatar
    South Carolina
    10,045
    Okay, if you add about ONE QUART of 8.25% bleach, it will raise your FC about 3ppm.
    That looks like a good place to start.
    What % bleach are you using?
    Jul 2013
    Nova Scotia, Canada
    17
    My bleach is 6%. I used the pool calc and it gave me 1.8 litrers. Would you add that all at once? Into the skimmer?
    Butterfly's Avatar
    South Carolina
    10,045
    Pour it slowly in front of a return with the pump running.
    Jul 2013
    Nova Scotia, Canada
    17
    Thanks! I'll give that a try. Our steps are starting to stain again; would you add more sequestrant before adding the bleach?
  20. Back To Top    #20
    Butterfly's Avatar
    South Carolina
    10,045
    Yes
