Thread: Whidster
    Whidster's Avatar
    Mar 2011
    Camas, WA
    68
    Whidster
    We are also having issues with Ph jumping up half a point in one day. I'll adjust to 7.5, then the next day it is up to 8.0. FC is also rising, and the SWG is at the minimum setting. Current numbers are: FC at 7.5, Ph at 8.0, TA at 80, CYA at 80. SWG salt reading at 2800, salt test shows 3200. It has been fairly warm, so pool wide open during the day. Pool at 82 deg. Suggestions on what to check on or do next?
    20,000 Gallon Vinyl Splash AG pool. Goldline SWG. Two sand filters w. 1.5HP Sgl Spd pumps. Lexan Aqua Shield dome. Solar heating, with propane back-up.
    Camas, WA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Whidster
    Have you had any aeration besides the swg? Has it been windy? You may need to let your TA drop a little further...you can go as low as 60 ppm TA if needed.
