Results 1 to 11 of 11
Thread: Clarifier - To use or not to use
    I have close to 4 full (big) bottles of SeaKlear Natural Clarifier. I have not used it since I converted to the BBB Method. Do I have a need for Clarifier or should I get rid of it? I use to buy it when I would get phosphates and the "pool people" told me to use it when they sold me the phosphate remover. In fact, SeaKlear sold phosphate remover with a small bottle of clarifier attached.
    Boy those people can really suck the money out of you! lol
    Installed Sept 2008. 18 x 36 Flatback Kidney Radiant, Vinyl liner 25,000 inground, Hayward Max-Flo 1 HP Pool Pump SP2807X10 (runs 24/7) , Hayward Pro-Series High Rate Sand Filter Model #S244T, Hayward Heat Pro, Frog chlorinator is turned off, TF-100 Test kit
    Location is Toronto, Ohio, overlooking the Mighty Ohio River. My river days are done. Sold the boat and Waverunner and now prefer a pool over the river.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Clarifier - To use or not to use
    I wouldn't use it for my water.
    Jeff
    30,431
    If you are properly managing your pool water, you will never have a need for clarifier. It's often ineffective, anyway.
    Thank you. I will be giving it to a friend, along with a case of TurboShock.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Maybe you should steer your friend to the forum !!
    Jeff
    30,431
    You might hang on to that turbo stuff. Is it tri-chlor, di-chlor or Cal Hypo? Look on the label.
    Poolife TurboShock 78% Calcium Hypochlorite Shock.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by Mellott98
    If you have room for the CH, there's no reason not to use the cal-hypo to chlorinate, since you've already paid for the stuff.
    CH is 260.
    CH was a lot higher last year (360) before I started using the BBB method. It is lower now due to having to drain a foot of water from the pool for the winter.
    Richard320's Avatar
    Jan 2010
    19,051
    Every pound of that stuff will raise CH by less than 3 in a pool the size of yours.
