Results 1 to 13 of 13
Thread: Permit question
    Permit question
    So I'm new to this. I have a guy scheduled to come out and install a 24' pool next week. The guy installing is not getting a permit and said 99% of the pools he installs permits are not pulled because they are a hassle to deal with. But it seems to me that the city might notice if I all the sudden used about 15 thousand gallons of water? Does anyone have experience with this? I'm not too worried about the permit, since we're going to make sure everything is up to code, but i do need to be able to put water in the pool!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Permit question
    I just went to my township building to get a permit. No biggie. They'll list everything you have to do to meet code.
    Jeff
    Jun 2013
    Fallsburg, NY
    258
    Re: Permit question
    Depends on where you live. I did the permit process for mine. In my town, any pool above 24" depth by design requires a permit. The trickiest part of the process was the workma's comp requirement. For the site plan I did a rough draft showing that the pool complied with the offset requirements (10' away from property line and 20' away from foundation). My first mistake was listing the landscaper who was doing the leveling as the contractor. Apparently you don't need a permit to move some dirt, and the inspector gave him a hard time, even though he has a workmans comp number. I then submitted a workmans comp exemption form listing myself as the person putting up the pool and claiming exemption from workmans comp rules. I had the permit within a couple days after that. They do investigate workmans comp exemptions in New York though, so I had to do the phone grilling a couple of days ago. Not a big deal unless you hired someone to help you put the pool up. (not including digging)
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    May 2013
    Tulsa, OK
    83
    Re: Permit question
    My Permit was a breeze. Simple drawing of the property with measurements
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Jun 2013
    Fallsburg, NY
    258
    Re: Permit question
    Quote Originally Posted by heavyweight_4u
    Yes, getting the permit wasn't too bad except for the Workman's Comp bit, but you need to be inspected post installation (or even during) to verify that you are complying with codes. Here in NY, that requires a removable or lockable ladder, walls at least 48" above grade, or you need a fence, a pool alarm which has some crazy requirements, (I still haven't installed the alarm because even I am not sure how to safely remove it from the pool without alerting the neighbors, let alone explaining the procedure to my mother-in-law and my wife who are the most frequent users of the pool). NY has very strict rules for pool alarms, don't expect to pay less than $100 for the alarm. My permit cost $100, lockable stairs, $250...Lockable deck with railing $1200, alarm, $100.... It's no wonder many people skip the permit process.
    May 2013
    Tulsa, OK
    83
    Re: Permit question
    Ouch. Ya nothing like that here. Or at least not yet. I get u permit Monday and pool goes up Tueday.
    njkat's Avatar
    Jul 2012
    Central New Jersey
    17
    Re: Permit question
    It took us 6 weeks before the town approved our pool permit last summer. I don't know why it took so long but it was very annoying as of course we wanted the pool ASAP !!! Then there were 2 different inspectors - one for the electrical and a different one for the rest of the work. The electrical inspector came back twice before he was totally satisfied with everything.
    Morada 24' x 52" round AGP, 13500 gals
    Waterway 1hp Horzintal Pump & Motor, Waterway Clearwater II 150 sq ft Cartridge Filter, Polaris 65, K-2006 Test Kit
    Jun 2013
    Miami,Fl
    9
    Re: Permit question
    I had no problems with my permits(Thank God) but I had four different inspectors...electrical...the pool itself then the pool fence & last but no least the deck floor.I only had one issue but solved it quickly...I had my telephone wire within 10 feet from the pool I moved it problem solved.Done Deal!!!
    Pool Size: 16'x32' 14,200 Gallons with spa
    Pool Type: Inground,Diamond Brite Blue Quartz
    Pump:STA-RITE 2hp Pump & AquaPure PLC700 SWG (New Version)
    Filter: STA-RITE PXC 150 Cartridge
    Mid Missouri
    227
    Re: Permit question
    I guess that depends on what you're paying for and your expectations. Are you paying "side job" money, or are you paying going rate for a professional installation? Are you saving enough to accept the risks of a sub standard job, an uninsured contractor or inconveniences for yourself later?
    Permits shouldn't be an issue for a professional to deal with. They will typically help to make sure you get a job done that is up to par and help protect you from issues that could arise later.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    Re: Permit question
    we got the permits because a.) the installer wouldn't install the pool without one which was fine with me and b.) I wanted to ensure we'd be covered from an insurance perspective if anything were to happen. The building inspector was great, tested our locking ladder three times and signed off. The electrical inspector was a jerk. Had us run a second line to where the pool outlet was for a convenience outlet and he was ****** I buried conduit but left both ends and 3 spots along the trench open for him to measure the depth. I was more concerned if I left a 100' long trench open for the week it took him to show up that a neighbor kid or one of our dogs would come along and step in it and twist/ break an ankle.
    21' AG (~11,000 gallons)
    Hayward S180T sand filter (35 gpm)
    Hayward Power-Flow SP1510 pump
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Permit question
    Insurance perspective is key. Has the OP contacted homeowners to ask about pool liability?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    Tulsa, OK
    83
    Re: Permit question
    Ya, we were required to due to city requirements....
    I had to argue with the girls in the permit office about a pre install electrical and plumbing inspection... She couldn't understand that an AGP was all self contained.
    She finally got an actual inspector on the phone and he let me know what all I needed. Which was only 60$ compared to 560$ which is what the young woman had quoted me.
    Jun 2013
    SpringHill FL
    415
    Re: Permit question
    I deal with permits very frequently as a contractor. As a home owner you should require the builder to obtain a permit for several reasons 1 to assure yourself you are getting an up to code structure(pool) the inspectors are a part of making sure your structure is safe and built correctly. 2 so you dont run into issues down the road because the builder did something incorrectly or is to close to any setbacks or existing structures. 3 simple peace of mind
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
