Thread: Jandy aqua pure 35
    Jandy aqua pure 35
    I recently installed the Jandy aqua pure system. It worked fine for about five months but now the chlorine level is greatly reduced, almost 0, and there is a brown scaly rust like coating on the Cell. My salt level is perfect and I have varied output levels without any change. Does anyone have any suggestions of what this problem could be? Any help is greatly appreciated!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Jandy aqua pure 35
    Welcome to tfp, Harblaw
    Please post a full set of test results. See: http://www.troublefreepool.com/pool-...efore_you_post
    The build up on your cell is likely calcium due to your pool chemistry. Your manual should have a procedure for using acid to remove the scale. Once we have you test numbers we can help you balance to pool so that you do not continue to have the problem. See: http://www.troublefreepool.com/pool-...ater_generator
