Thread: Is Malathion a problem?
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Last night my wife and I were hanging out with our back door open to the pool area. All of a sudden my wife smells something that smelled like plastic or rubber burning. We frantically looked around but couldn't find anything. We thought maybe someone was burning something in the neighborhood. My wife walked around the neighborhood and found that the neighbor right behind us was spraying Malathion on the Bradford Pears just behind our back fence. We closed our doors and thought nothing of it. Our son went swimming about an hour ago and he immediately got out saying the water smelled like the air did last night. Do I need to worry about anything? I checked my chemistry and everything is within range.
    Thanks!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Donldson's Avatar
    NW Ohio
    2,904
    Re: Is Malathion a problem?
    If anyone has head lice invite them over for a swim!
    Seriously though, I found this on the NY health department site:
    9. Should I be concerned about my private swimming pool?
    Malathion breaks down fairly quickly in water and in sunlight. No special precautions or waiting periods are needed for swimming pools. However, if you have a pool cover, you may wish to use it before spraying.
    I would just make sure there is plenty of chlorine in tonight and keep the pumps and waterfalls running to help any remnants break down.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Oct 2012
    604
    Thanks Donldson, I will do that! We are getting plenty of sunlight.
    Mar 2007
    San Rafael, CA USA
    12,082
    This paper talks about the chlorination of malathion, but that is in the context of dry flour, not in water. The malathion degradation pathway in water is described in this reference where in water it breaks down to produce ethanol, malic acid and O,O-dimethylphosphorothionic acid. At pH 8.0, it has a half-life of 1.4 days so at pool pH the half-life is probably a few days to a week and that's not counting the oxidizing effect of chlorine.
    Oct 2012
    604
    Thank you Chem Geek!
