Results 1 to 14 of 14
Thread: Power Washing and Deck Restoration
    Central VA
    31
    Hey everyone,
    I am a fairly new pool owner and have gotten a lot of info from here. I would really like to be able to give back to the site. I am a pressure washing and deck restoration contractor, so if anyone has any questions related to that, just ask.
    18' round Intex using BBB
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    power washing
    Hi Chris, to make a really long story short, my hubby and I spent hours refinishing our deck...in some spots the new stain is flaking off. Do you think that is due to not removing the cleaner solution adequately? In other areas it looks great, just a few spots it flaked away. I would hate to redo the whole thing, can we just put on a new coat of stain? Does it need to be pressure washed before or can we just go over the first coat? We applied the stain last August. Thanks!
    Central VA
    31
    Re: power washing
    Quote Originally Posted by frustratedpoolmom
    Do you remember what kind of finish you used? It sounds like and acrylic, and that's probably where you problem is. The more the foot traffic, the faster the flaking. An acrylic just forms a film on the wood, opposed to oil which penatrates.
    What kind of cleaning solution was it? What ever it was, it probably needed to be neutralized with and acid based product before applying the stain.
    As far as a 2nd coat, I'll wait on your response to elaborate.
    11,969
    Well, It's been awhile, so I looked online as it was Behr products. We used a stripper to remove old stain and prepare new wood (the deck was a combo of old deck and new addition), that only needed to be washed off with a pressure washer, I'm pretty sure we followed the directions. My best guess is we missed a few spots, because for the most part it looks pretty good.... The stain was a "penetrating" stain but looking at the photos of their product I'm pretty sure it was latex based and I do remember using soap and water to clean-up.
    Central VA
    31
    If it was soap and water clean up, it wasn't oil. You can find some contractors that will strip acrylic, but it can get expensive. Most people don't want to put up the $$$, so your kinda stuck with it. If it is of that much concern to you, I would spray thedeck with a solution of 1-2% bleach mixed with a squirt of lemon Joy and rinse with a pressure washer. This should kill any mold and mildew. Re-coat the flaking areas. When it dries, if it didn't blend well, do the rest of the floor minus the re-coated, flaky areas. Also, I doubt that you missed any spots, that's just the nature of acrylic deck stain. It sucks, because it looks so good on the sample boards at Home Depot. Unfortunately, they are selling you a inferior product.
    New Brunswick Canada
    819
    Chris
    You are suggesting pressure washing for decks?
    Its a major no no, you are opening and loosening the fibres. I have seen decks done this way, and easily having 1/8" of wood removed. No to mention the deck having that buzzed hair cut look.
    I have built alot of decks and always recommend sanding if one wants to remove a oil based stain, or stripper if its paint. One can easily rent a belt sander from HD or Lowes and do the job in a an afternoon. Not to mention the final look and feel of the freshly sanded wood is amazing. One problem we have in Canada with PT Spruce, is we ship all our good stuff south. So the stuff we get up here is almost considered a rough finish. Ok if one is going to apply paint, but we all know paint on a deck around a pool will only cause heat retention.
    I am curious what pressure you are using when you use your sprayers? I am willing to bet you could easily convert your company to a deck renewel company, sand them suckers back the same amount and get an exquisite finish.
    Your comments?
    Rik
    Central VA
    31
    Quote Originally Posted by pooladdict
    Chris
    Your comments?
    Rik
    I suggest pressure washing when the person holding the wand knows what they are doing. A deck can be severely damaged by a sander as quickly as a pressure washer. Knowledge is key.
    ETA: You made a good point in another thread about proper ventilation under a deck. Lanscaping and lattice can be beautiful, but if it inhibits the ground from drying underneath the deck, your deck will basically rot from underneath. PT wood is rot-resistant, not rot-proof.
    11,969
    We used a pressure washer when we stripped our deck, we had no problems except for a couple of spindle -thingys that we got too close to. We had to sand the deck anyway because we wanted to ensure a splinterless summer. I think if one is carefull and doesn't get too close with the washer raising the grain isn't a for-sure result, only if one is careless...
    I think the problem with presure washers is that people use them to try and strip off a finish. I know I'm guilty of ruining quite a few sextions of picket fencing with an overly agressive use of a pressure washer.
    ~Megan
    Jul 2007
    ontario, canada
    82
    This forum is turning out to be even more useful than I'd expected. We just had to build new stairs up to our deck on the second floor and since I want to redo the upper deck at some point we did them in Cedar since it was on for almost the same price as PT. Anyway...the upper deck has that dark brown stain on it that I'm really not at all fond of. It's coming off in many places as the past owners did it long ago. I'd like to pressure wash what's left of it off and then just repain the ballusters maybe the colour of my house trim until I can afford the cedar to replace the decking.
    I'm going back and forth between buying/renting a pressure washer and would love some advice on the entire process from this point.
    If you have a few minutes and could help me out I'd be very grateful.
    N
    [color=#0000BF]16x32 inground vinyl liner approx 23 000 gallons
    22" cyclone sand filter, 1 HP pump
    solar cover, solar heating panels
    Taylor K-2006 test kit
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    pressure washing decks
    I think the big key here is know how. I have pressure washed many decks before and as long as your careful and patient it can come out great. Now sanding it is another story. I think most decks would take an entire weekend if not more to sand and then you better hope you know what your doing or you'll mess it up royally. As far as buyimg your own. I did. It costs less in the long run. Make sure you start slowly and maybe test out some wood that doesn't matter first. I started with my house and after a few hours I got the hang of it. Anyone can do it I think. Just remember when you first start out don't use the most harsh angle and don't get too close to your wood. I'm sure the experts can give more in depth tips on pressure washing correctly.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Central Florida
    84
    Re: Power Washing and Deck Restoration
    We have a paver deck around the pool and under our covered lanai. It is approx. 2 yrs old and the outside part is faded vs the covered. We want to seal the pavers but do not know what type of work is involved and what type of sealer is the best. Also, it's either black dirt or fungi getting in between the pavers on the outside area, is there a way to clean this out and seal these areas. I heard there was a sand like product you could use to seal the spaces.
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    Guest
    I have a cedar deck that has some holes in it from carpenter bees. The previous owner had stained the deck, no idea what product he used but it's pretty faded. Deck was installed about 10 years ago.
    I have some PT fencing that was installed over 10 years ago, but it's in great shape. Doesn't seem to have any stain on it.
    I want to add some more fencing and am "on the fence" about whether to buy cedar or PT. I know that there have been changes in how PT wood is treated. Some fencing companies want to install all PT, some PT posts and cedar pickets, others want to install all cedar pickets and posts. And there's always the stuff at Home Depot. Any suggestions?
    Thanks.
    Sue
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    405
    Chris-
    I'm just finishing up my screened porch. Its all PT except the Trex flooring. Whats your take on;
    - How long I should wait before sealing/staining? I heard I should give the lumber a few months to age/dry.
    - If I wait too long will the lumber start to crack?
    - What do you recommend for sealing/staining (brands and steps)? I'm planning to use a light brown/cedar color.
    TIA,
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
