Results 1 to 16 of 16
Thread: Is "Bright and Soft" ok to use as salt ?
    vanessadickson's Avatar
    Jun 2012
    Kentucky
    61
    the Diamond Crystal product Bright and Soft salt pellets they have at Home Depot, no chemical composition on bag. Is this OK for a SWG? At store now, appreciate any help.
    38,900 gal., UG, vinyl, SWG, Hayward w/T-15, 1.0HP pump, sand filter, Aquabot Turbo-T
    38,290
    Re: Is "Bright and Soft" ok to use as salt ?
    Don't they have solar salt? That is certainly ok ... will have to look up the Bright and Soft.
    38,290
    Well, the Bright and Soft has a higher salt content (99.8%) than the solar salt (99.6%), but I would be wary of what "Advanced Performance formula—for softener efficiency" means.
    Their Iron Fighter pellets are 99.6% as well, but that DEFINITELY has stuff in it you do not want ... personally I would stick with the Solar Naturals.
    Jun 2012
    Kentucky
    61
    Believe it or not, they have no solar salt. Just those pellets. I'll go elsewhere
    Jun 2012
    Kentucky
    61
    First stop was a pool store that tried to sell me bags of their "salt" with a bunch of cya in it (no thanks), claiming I couldn't handle the PH change using just regular salt. Hold your breath when I tell you what they wanted for their special salt--$250 for about 120 pounds of salt. hahahahaaa.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good move, someone likely has some close to you. Good Luck.
    Essential Links:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by vanessadickson
    250.00??????? C YA!!!
    EDIT: ph CHANGE???
    Essential Links:
    38,290
    I get mine from Lowes ... Morton brand solar salt $4.78 / 40 lbs. They also have the pool salt (same as solar just ground up more) for $5.87. Usually I have see the regular pool salt at pool stores for around $7-8 / 40 lbs.
    I just can not even guess how they can try to justify paying over 10x as much for a little CYA mixed in.
    Jun 2012
    Kentucky
    61
    Happy ending-Lowes has the Diamond Crystal Solar Salt, at 5$ a 40 lb bag, that'll set me back $15
    instead of $250 plus wacky cya. And the score is: Pool owner 1, pool store 0.
    Jun 2012
    Howell, NJ
    977
    What pool store was it? Do they have a website? I'd like to see the listing for their salt, and see what "special" additives it has.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2012
    Kentucky
    61
    It was biogard's Mineral Springs.
    Jun 2012
    Howell, NJ
    977
    According to the MSDS it is just a bunch of fancy salts and some acid. I wonder how they can justify the price. Side note, I wonder if the aluminum salt can cause metal staining problems? Anyway, good thing you didn't buy it.
    John
    Donldson's Avatar
    NW Ohio
    2,894
    I vote this statement for an awesomeness award!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Was that "Bright and Soft" or "NOT-So-Bright and Soft"
    The other enhancements sound like "wallet empty-ier" enhancements.
    -- Guy --
    Donldson's Avatar
    NW Ohio
    2,894
    Quote Originally Posted by techguy
    Was that "Bright and Soft" or "NOT-So-Bright and Soft".
    hehehe
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    To follow thru with TechGuy: NOT-So-Bright and Soft-In-The-Head.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
