Thread: DIYer work on delaminated plaster
    May 2012
    Moreno Valley, CA
    12
    Back in December 2011, I bought a REO property at Moreno Valley, California. This was originally owned by a bank after foreclosure. Based on my investigation and had found out the previous owner had neglected basic house keeping around the house, especially the pool for around 20 years since they brought brand new. Pool was monstrously green and I had to drain half way down and fill. Apply shock treatment via BBB method. Now, pool is well balanced with BBB and little bit of stablized chlorine tablets from time to time to ensure its in 30 to 40 CYA
    As you can see in pictures I linked to this thread, the pool plaster surface is now completely delaminated, along with broken waterline tiles. Cracks in concrete wall between spa and pool.
    I am considering of hiring a contractor specializing in peppletec installations, but before doing that. I would like to minimize cost in pool renovation by doing preparation work by myself. Work will commence after summer ends and before winter starts ensuring not to go over 85F, preventing from concrete walls expanding and shrinking due to heat
    Removing waterline tiles
    chipping away plaster and removal to tip
    Repairing (loose concrete), cleaning(acid wash) and filling concrete cracks(epoxy resin)
    Acid wash Shotcrete walls. I have a 4,000PSI gas powered water cleaner, would this work?
    Apply new waterline tiles
    Pool contractor would do in the following
    Replacing broken spa jets with new ones.
    Fix, repair and possibly replace pool lights (these aren't working, electrically)
    Install Weir flap for pool skimmer
    Apply Peppletec
    What I would like to know from experts in this forum. What processes, resources needed, tools and chemicals can I use to do the work by myself.
    Lastly, any Peppletec contractor in Riverside County do you recommend? I would love to reach out to them and obtain quotes.
    https://docs.google.com/file/d/0B_bo...it?usp=sharing
    15,000 Gallon IG Gunite with Spa with PebbleFina Pool Surface. Raypak 84 Professional (Model 409) 400k BTU gas heater. Pentair IntelliflowXF Variable Flow Pump.
    J&J Colorsplash LXG LED pool and spa fixtures. CircuPool RJ-60 PLUS Salt Chlorine Generator. Hayward Navigator Pro pool cleaner
    38,251
    Re: DIYer work on delaminated plaster
    Well if you check the PebbleTec website there are only 3 approved installers in Riverside:
    Baron Pool Plastering
    Gardner Pool Plastering, Inc. - Indio
    Tony Marquez Pool Plastering
    It should be cheaper to contract with them directly than through a pool company who will just sub to one of the 3. Although they will only do the jets and pebble install, may need someone else for the lights / skimmer ... but I am sure they could refer you to someone for those if they do not do it.
