Thread: When do you consider it turning color?
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    When Testing say TA and you add drops until the color goes from green to red, when do you consider the last drop..? When the color is solid red and staying or when it turns slightly to red or when it flashes red then basically goes to clear or a very light green. With the CL test it turns clear and that is a very easy test to see. Just not sure about the TA. I have been counting drops until it turns slightly red and stays.
    Retired Navy Chief (CTOC)
    21ft round 4ft AG 9367 gallons, floater with pucks as needed, Waterway PB 19inch Sand, Waterway PB 1hp SPL (not sure of type), Rheem LP Heater, Hayward Aqua bug, Aqua Luminator Light. Located in Iowa.
    Re: When do you consider it turning color?
    Once the color starts changing, you continue adding drops as long as the color continues to change. The final drop, which does not change the color any further, does not count.
    Smykowski's Avatar
    Sep 2011
    3,065
    To add a bit more, a shade change (light red to medium red, or medium red to barbie pink) also counts as a color change. No change means you add a drop and nothing happens at all.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,100
    Keep adding drops until the color stays the same for two drops in a row. Subtract the last drop and that is your total.
    IE.....Drops 10 and 11 stay the same color. Your TA is 100.
    [youtube:3gkwx1iz]tFGmZI2yXcQ[/youtube:3gkwx1iz]
    drmac22's Avatar
    May 2013
    Swisher, Iowa
    35
    Thanks! I was not quite adding enough drops. Should be a little more accurate now.
    jgofnj's Avatar
    May 2013
    Hillsborough, NJ
    167
    It also helps if you have the magnetic mixer. A lot less guessing.
    20,000 gal, In-Ground (built in 2007)
    Vinyl lining / 1HP Hayward SuperPump / Hayward Pro-Grid DE Filter / Hayward Gas Heater / Liquid Chlorine,Bleach (4 Gallon Liquidator)
    Dohney Discovery Robot
    Testing Method: TFTestkits/TF-100
