Thread: Jets spewing white
    Jul 2013
    Minnesota
    27
    Jets spewing white
    Yesterday I was cleaning my pool a little and sucked up a bit of air. The jets blew "white" for a surprising amount of time. Does anyone suspect anything wrong other than just blowing the air back into the pool?
    18'x36' In ground pool - roughly 25,000 gallons; Sand filter; Vinyl liner;
    38,260
    Re: Jets spewing white
    If it stopped and there is nothing on the floor now ... then it was probably just air. You likely could have purged the air out of the filter with the air relief valve (assuming you have one).
    Jul 2013
    Minnesota
    27
    Yes, I have an air relief valve and I usually purge air out. This was just an immediate reaction to sucking up air while cleaning the pool.
    I'm just a bit paranoid since I've been fighting a cloudy water issue this summer and the water is finally crystal clear.
