Results 1 to 19 of 19
Thread: In-floor cleaning system
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Hello,
    I have a brand new pool, and purchased it with an in-floor cleaning system from Paramount. My problem is with the MDXr3 drain not having any suction.
    When the salesman explained the system to me he told me that these drains had so much suction that they had to install two safety mechanisms along with it to keep people from drowning (I was impressed).
    Anyway, the pool is now built and I decided to chance my life and get near this man made "black hole" and I have to say that I was suddenly very unimpressed. I didn't feel any suction, I went so far as to put a leaf within 6 inches of the inlet and it just blew away from drain. I grabbed my little leaf and stuffed it directly into the drain, and that did get pulled to the waste canister.
    I called my PB and they showed up and promptly blew out the lines between the canister and drain, they didn't find any obstructions. They told me the system was operating normally and that I would have to shut off my skimmers to force more suction from the drain. They piped my system in such a way that I can only shut-off one of the two skimmers at a time, and as you can guess, this made little to no difference to the main.
    I've cleaned my cartridge filters and checked for obstructions at the impeller but I'm still getting no suction.
    I was hoping someone out there with a similar system could tell me what their experience was with the drain. Maybe I'm expecting more suction than it was designed for?
    George
    32k gal IG free form / Vinyl Liner (cement wall) / Jandy 2 HP FloPro
    LRZ400EN Heater / Jandy CV460 Cart. Filter
    Paramount Vantage in-floor pool cleaner / built April 2013
    Pool Equipment Picture (on Flickr)
    38,322
    Re: In-floor cleaning system
    Welcome to TFP!!!
    I am not too familiar with that system. But, I was curious if you have float diverters in your skimmers under the basket. You may be able to add one to the "open" skimmer to block a majority of the suction from it and thus have more from the pop-up drain.
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Hi Jason,
    Thanks for replying. I'm pretty sure I don't have float diverters, I only see the drain when I take my baskets out. I can probably rig something with the vac hose to shut down the skimmer, I'll give that a shot and see if I get any real suction out of the drain.
    George
    38,322
    What does the inside of your skimmer look like under the basket? Probably easy to add a diverter.
    Or you could test if that helps by just sticky a tennis ball over the skimmer suction line.
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Basically a bucket with two holes at the bottom
    George
    38,322
    Is one of the hole plugged? Or is it connected to a hole in the wall below the skimmer or to the floor?
    Either way, plug the suction line with a ball and see if the floor works better.
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    yes, one of the holes is plugged.
    I tried the tennis ball trick and did get some extra suction at the drain. Not as much as I was thought, but my maybe my expectations are a little too high.
    Thanks for the advice...
    George
    mas985's Avatar
    Pleasanton, CA
    11,741
    Is the in-floor cleaner not keeping the pool clean? Most in-floors require the popups to push the debris to the drain and the drain captures the debris but it really doesn't pull it in from very far away on it's own.
    Mark
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    So far the pool is clean, and the floor jets do a great job of moving the debris towards the drain. My problem is that I often see leaves float right past the mouth of the drain. The only way things get sucked up is if they are pushed into the opening of the drain. I have actually placed leaves at the rim and have watched them float away!
    I stupidly laid two fingers across the drain of both my skimmers and the suction nearly tore my skin as my fingers were pulled in, I tried the same thing at the debris collector for the drain and I didn't feel nearly as much suction.
    George
    mas985's Avatar
    Pleasanton, CA
    11,741
    Can you post a picture of your equipment/plumbing?
    Mark
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Sure, this is a few months old while pool was being installed.
    George
    mas985's Avatar
    Pleasanton, CA
    11,741
    On the skimmer valve, can you turn it so it shuts off both skimmers? Some valves have stops but you can get around them by unscrewing the valve handle screw and lifting up a little bit. Also, are those all 2" lines?
    Mark
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    I popped off one of the little black pegs, this allowed me to shut off both skimmers. It did increase suction at the drain, when I laid my hands over the drain I could now feel a little flow, but not so much that you would have to install safety release mechanisms like my PB did.
    George
    mas985's Avatar
    Pleasanton, CA
    11,741
    What is the filter pressure and what is the cleaner valve pressure?
    Mark
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    I'm at work at the moment, I'll have to get those numbers for you when I get home this evening.
    Thanks for helping...
    George
    May 2013
    North East Ohio
    959
    Not that his helps, but my PB told me the same thing about my two main drains...and like you I can barely feel the suction. I do have 2" lines everywhere - I think PB are just over selling some things to get us excited.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Mark: Sorry I got home late and it was pouring rain, I'll get you those numbers tomorrow....
    toofast: I think you maybe right. Even though I'm complaining about the suction, the pool is spotless and I've haven't used a vaccum yet. I guess I'm just a little OCD about the drain at this point....
    George
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    My in-floor cleaner works like yours. I often see debris blow past the main drain. However, my pool is also spotless so I don't worry about it.
    Much like you, when I first got the pool, I was picturing something like a shop vac. I thought if anything got near the drain it would get sucked in. It is not so.
    I'm on my third year using it and love it. It basically works on the law of averages. The jets keep everything stirred up and eventually debris will hit the drain and get sucked in.
    If the pool is clean, I would not worry about it.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Thanks for the info Carlos. Unfortunately I just ordered a gasket and non-fused cover for my debris canister. I guess I should stop obsessing and just enjoy my clean pool!
    George
