Thread: Sudden PH spikes?
    Apr 2013
    NE Oklahoma
    53
    Sudden PH spikes?
    I go out and skim and take a look at the pool every morning and test the water roughly 3-4 times a week. About every other day or two.
    Yesterday the water chemistry was perfect.
    Son didn't know I tested it yesterday and tested it this morning. It is very high PH. I retested and sure enough it went from 7.6 to darker than the highest color code.
    That's the second time the Ph spiked suddenly and dramatically.
    Can anyone tell me why that is? The water looks crystal clear. I just used the broom on it the other day. The swg is going 8 hours per day. The free chlorine and combined chlorine are spot on.
    I can't think of anything we've done that could cause it. The man looked up stuff with google and said he thinks the kids making whirlpools aerated the pool too much and caused it. Seriously? I don't think so and even if it is, I'm not going to yell and the kids to quite swimming in circles. It's some kind of child requirement in a pool, to make the biggest whirlpool they can, right? ;p
    M
    Newbie to pool ownership.
    5000 gallons
    Intex Krystal Clear sand filter pump 16" & saltwater system model CS20110
    AG Intex 16' x 48" Ultra Frame
    Leslie Chlorine FAS-DPD Service Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Sudden PH spikes?
    What is your FC, CC, TA and cya?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    In addition to Linen's question. Aeration can cause PH to go up usually not fast, have you added water recently? What PH is your fill water? Low TA can cause quick swings in PH.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your TA is likely too high for a SWG, and the aeration from the SWG is adding to your pH rise. As requested, please post all the numbers so we can have a better look.
    Essential Links:
    Apr 2013
    NE Oklahoma
    53
    Sorry it took me awhile to get back to you.
    This morning I added the bleach and later the acid.
    I know those will fix the numbers. But what can I do to keep things more level?
    FC 2
    Ph 8
    TA 100
    Calcium 110
    Cya - 70
    Oh I just want to give a huge thanks for this board. It was a ton of work putting the pool in but it has not been nearly has much a pita as everyone else I know IRL seems to think a pool is to maintain.
    My father in law was saying what a nightmare a pool is to maintain and I was completely baffled. Once it's properly set up - test the water a few times a week and vac it maybe every 2 weeks. I skim it with the net before swimming. That's it. I'm certainly not "spending hours a week" maintaining it. *confused*
    M
    5000 gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well you are right. Most people just never take the time to learn about Pool Chemistry, and end up in a constant battle with the pool.
    Your pH needs to come down and it would help to push that TA down as well. How to do that is in Pool School, but you will keep pushing the pH down to about 7.2 and aerate to raise it over and over until the TA is where you want it. Your SWG pool will do better when you get TA in the 60-80 range. Otherwise you will continue to fight this upward movement of pH which is common with a SWG. I didn't state the obvious, but guess I should mention that your FC is way low... Glad you are enjoying the forum.
    Essential Links:
