Thread: Please recommend a vacuum for 15' intex pool
    I have been searching amazon for a pool vac that we can use with our Intex pool 15' diameter 48" deep. We borrowed our friend's intex pool vac that hooked up to the hose and has a small bag attached but it didn't seem heavy duty enough and most of the "stuff" didn't get caught in the bag. What vacuum do you use?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Please recommend a vacuum for 15' intex pool
    For smaller intex pools that run with the original style pump and filter it is usually best to get a stand alone type of vacuum, such as an aqua broom. If you search for an aqua broom in google it will pull up several small pool vacuums that you could look at.
    Love TFP? Become a
    TFP Supporter!
    DigbyAllen's Avatar
    Westchester, NY
    113
    I bought 18' of 1 1/2" hose and use my pump/filter to vacuum my 15' pool just like a big pool. One end I plug into the filter inlet on the side of the pool after unscrewing the strainer grid. I use the Intex venturi vacuum head and I plug the other end of the hose into it. It is a very cheap solution that works well for me.
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I highly recommend the Pool Blaster Max / Max HD. Ie. Other Max variants, there have been many.
    It's really great and totally independent of your pump. It'll do a better job than your typical above ground pump and filter ever could, not to mention it's not too expensive and seems to last quite a long time if properly cared for.
    Search the forum for 1st hand accounts of its use and reviews. Quite a few users of it here.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
