Thread: Solar Salt
    Solar Salt
    Hi;
    We have noticed some itching after swimming recently and are thinking about adding some solar salt.
    FC=5
    CC=0
    PH=7.5-7.6
    TA=100
    CYA=30-35
    CH=350+
    Usually add about 45 oz. daily of chlorine.
    What is the proper way to add the salt? Pool calculator indicates 250 lbs. for a goal of 1500 ppm.
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Solar Salt
    Throw it in, I've seen something here about calling it diamond day.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Re: Solar Salt
    Thanks, Dan, that's something even I can do!!
    Gary R.
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Re: Solar Salt
    I just added salt and its great!!! only advice is add half of the 250lbs, swim in it and see if you want to add the rest. Some people can taste different levels of salt while others can not at all.
    IG 16x32 Grecian - Vinyl - Approx 18k gal - 1 HP Hayward Super Pump - Pentair Triton II TR-60 Sand Filter - Hayward ColorLogic Light - Hayward H250FD Heater
