Slam ph question
Jul 17, 2013
2
I am just starting my first slam. Ph before start was 7.6. I added a little more liquid chlorine than calculation suggested (pool shop said CC was 1.1, calc was about 6litres i did 8). Now ph is 8.5, my auto chem. unit is slowly bring it down by dripping in acid. Question: do I even want to reduce ph? Should I just unplug the acid feed and leave filter on and leave ph where it is? Or should I manually dose required acid to drop ph 7.6?
Welcome to TFP!
pH testing will be inaccurate while your chlorine level is high. I wouldn't adjust it until you are back to normal chlorine levels.
