Thread: lap pool design
    lap pool design
    What are your thoughts on a 12' wide pool (x 50' long)? Too narrow? [Yes, I know no one ever says I wish my pool were narrower or shorter.] How many strainer/suction ports going back to the filter? And where would you put them? How many lights and where would you put them? Would putting the pump station below surface level not be recommended? If there were a leak around the pumps you could drain the pool.
    Fred
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: lap pool design
    Most above ground pools have the equipment below water level, and yes equipment breakage does sometimes lead to draining the pool but not often. Could probably get by with one return and skimmer at opposite ends. It would be harder to swim in one direction than the other when the pump was on. Generally recommended for lights to point away from entertainment areas to avoid glare.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: lap pool design
    My pool is 43' long. 5' are taken up by steps. So if/when i swim laps, i've got 40' to work with. 40' is way to short in my opinion. I find swimming in circles works better for me.
    I think if you are a serious swimmer, you'd want it longer.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Apr 2013
    DFW, TX
    72
    Re: lap pool design
    Our pool (under construction) is not a rectangle but its designed to be a lap pool. 54'x14' at the widest point (not counting the tanning ledge) and 54'x8' at the narrowest point.
    I really wanted to go to 60' but had to make some design adjustments. I'd say if you are getting primarily a lap pool go to 60' if you can.
    I think 12' is not narrow at all. I have researched a lot and looked for pictures of residential lap pools and usually they are long and narrow. 12' being one one of the wider widths.
