Results 1 to 11 of 11
Thread: Glueing Rock together
    Apr 2013
    Westside LA, CA
    49
    my daughter just dropped the round skimmer cover made out of sandstone on the floor breaking it into multiple pieces - any idea how to glue them back together?
    32x15 IG Borate+Salt, Pentair VS+SVRS, howard swim pure 40 SWG, Pentair 4000 48sqft DE, Mastertemp 300, Electric Pool Cover, Polaris P93, 4 Kids for Aeration, ;)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Glueing Rock together
    Some sort of epoxy for ceramics maybe?
    Apr 2010
    East Texas
    9,572
    Or glue it all together on a very thin metal backing plate?
    Jun 2013
    SpringHill FL
    415
    Yeah sandstone will be tough to glue alone. You will need some kind of backer plate to fasten it all together with. Or maybe look into having anotherone made perhaps
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    You might try Gorilla Glue. I've used it on concrete and stone. It may not look perfect after gluing but is should be pretty strong.
    Gorilla Glue
    You can get it at Walmart or the big home improvement centers.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Apr 2013
    Westside LA, CA
    49
    I'll go the Gorilla Glue route + will add back support with either metal or hard plastic... let's see what I'll find laying around - thanks for everybody's suggestions.
    Loctite PL landscape block adhesive. you can find it at lowes.
    http://www.lowes.com/pd_214677-69-16543 ... 982&rpp=32
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    415
    Ditto on landscape block adhesive.
    Made for stone and wet applications.
    Then maybe some underside blocking with strips of brick or granite
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by blakeusa
    That's the stuff
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Apr 2013
    Westside LA, CA
    49
    time for an other trip to lowes...
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    I used that landscape block adhesive on some walls and if I remember it was white. The gorilla glue is a polyurethane adhesive and dries semi clear.
