Thread: CYA testing with Taylor K-2006
    May 2012
    Allentown, PA
    219
    This should be quick. Added more than enough CYA to be at 70-80ppm for my SWG. Taylor kit is reading 55ish. Should I add more CYA. I'm trying to lower my SWG setting from 80% 8 hours a day to closer to 40 or 50%. Maybe I have great eyesight, but i can see the dot very slightly at 70ppm when testing.
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: CYA testing with Taylor K-2006
    How long has it been since you added CYA ? It can sometimes take up to a week to fully dissolve.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    What he said ^^^
    It's easy enough to raise CYA, but there's no easy way to remove it.
    May 2012
    Allentown, PA
    219
    It has been about 2 1/2 weeks
