Results 1 to 16 of 16
Thread: How to Keep Above Ground Pools Cold??
    Hi everyone!
    I have a 10' x 30" round Intex above ground pool. And it is HOT outside. And so is my pool! I did some research and it looks like this is the only way to keep the pool water cold: http://www.mistcooling.com/mist-cooling ... round.html
    Has anyone had any experiences with something like this? Or are there any other ideas on how to keep my pool water cold? I have a cover; it does absolutely nothing. Thanks everyone!
    Re: How to Keep Above Ground Pools Cold??
    Yes, this what you want. But DON'T buy it. Build it yourself, it will cost less than $10.
    I'll find some links and add to this post.
    This will get you started, no need to use a bolt, just buy a male and female threaded adapter and for the top get an end cap. Everything you need will be in the PVC aisle at any home improvement store.
    dane-s-how-to-for-a-quick-easy-pool-cooler-t36086.html
    Here is my thread which shows different parts I've made.
    fountain-with-multiple-configurations-pics-and-video-t36183.html
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Awesome! Thank you!
    No problem -- buy plenty of pvc pipe and extra parts, it's cheap and I definitely enjoyed making extra pieces. Just made a new "spray bar," last night with smaller holes so I can use it with my pump on low.
    Aaron
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What type of cover do you have? If it is somewhat light blocking, leaving it on when the sun is on the pool may help some.
    Leaving the cover off at night should cool the pool.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Hey thanks Speedo for posting my project. I hope it continues to help members stay cool. Just when I thought I wouldn't be using that cooler this year the current heat spike proves me wrong. My pool water hit 88 today so I might run it Friday night.
    Jun 2012
    Howell, NJ
    977
    Hah, you think 88 is hot? Mine hit 97 today. I'm saving the heat for the end of the season, though.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    ..... Or, we could just switch kids. Had to turn the heater on today even though it was over 90 degrees the last two days.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jun 2013
    Ohio
    53
    Won't that restrict the return flow and damage the pump?
    Intex Ultra Frame 18x48; Intex 56671EG 2,650-Gallon Sand Filter Pump; Intex Krystal Clear Saltwater System 15,000 Gallon
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by jguard68
    As long as there is some flow there is no problem with restriction. The restriction lowers the flow rate and that actually makes the pump work less.
    for my intex ultra frame i got one of these sprinklers, attached it to the hose, and wrapped the hose around one of the beams. instant fountain for $3.
    http://www.lowes.com/pd_46876-306-876SC ... ct_price|0
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by ugafan
    How are you plumbing that to your pool pump to cool the water?
    Quote Originally Posted by linen
    i don't have it plumbed to to the pool because i don't run the filter when i'm in the pool. i simply ran a garden hose to the pool and wrapped it around one of the vertical beams. the sprinkler screws into the garden hose.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would agree it could make a neat fountain, but the cooling the op is asking for is not there. To significantly cool a pool with a fountain, the pools water needs to be run through it.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Just to add, the pressure at my filter doesn't change much when the cooler is running. All of those tiny holes add up to one big hole. ...more or less.
    I did use my cooler Friday night from 8 PM to 8 AM this morning. Starting water temp was 88 with air temp of 92. Overnight air temp dropped to around 75 with around 75% humidity. My pool water temp dropped to 80. Not bad.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We run the solar heaters at night instead of the day. It definitely works!!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
