Thread: How long did your SLAM take...
    Jul 2013
    Southern Delaware
    71
    If you care to list the length to complete a SLAM, just for my own interests
    Thanks
    13500 Gal. Above Ground. Vinyl. Hayward E-100 Highrate Sand Filter with Hayward Power Flow LX pump. Installed 2006.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: How long did your SLAM take...
    I had a green swamp when I opened this year and it took 3 days. I have a DE filter which helps speed things along. I stayed up late, woke up once during the night and woke up early. I hit it hard every hour (from 6 to midnight), scrubbed every other hour and made sure to get enough supplies on hand. I already knew about the BBB/TFP way, so I was able to start with knowledge (thanks to this website) which is the most important part of the process. I also turned on my polaris at the end of day 1. I think the polaris helps pick up more debris and circulate the water.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
