Thread: Pool Slide Water Ports Scratch people
    wjr75's Avatar
    Jun 2013
    IL
    836
    Hi Guys,
    We have a pool slide that I'm not sure of the type but attached a photo. The water ports on the sides are like a cheese grater. We have had two people get scratched when going down and rubbing on them. Are there any caps or new ports that won't scratch people?
    Thanks!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Pool Slide Water Ports Scratch people
    Got a closeup of the ports?
    wjr75's Avatar
    Jun 2013
    IL
    836
    Here is a close up.
    If the holes in the ports are just jagged or sharp I'd sand them with some fairly fine sand paper (~220 grit) to smooth up the edges.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
