Thread: Accidently left the hose on for ~17 hours
    Left the hose on all night and all day while at work. Happened to remember that it was still on while I was at work and a friend was nearby to go shut it off. Well the water was right at the edge! I was so mad at myself that I forgot this, my water bill is going to probably suck
    Everything should be okay, right?(as in equipment and liner. Seems fine)
    I put it back down to the normal water level as soon as I got home at ~4, then I cleaned it. Now i'm checking the water levels 8 hours later:
    I checked twice, did I really lose 1000ppm of salt because of this? I dont doubt the results, just wasnt expecting to lose that much.
    FC - 0 (the SWG has been off since earlier, heading out there with bleach in a second)
    TC - 0
    TA - ~95
    CYA - 50
    pH 7.8
    Salt - 2310 (3250 recommended, I had it at ~3400 last time I had checked not too long ago)
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Accidently left the hose on for ~17 hours
    Don't feel too bad, I think most of us have done something like that at one point
    Ike
    p.s. that is a very unusual pool you have there, does it have a flat bottom, or does it slope?
    22,542
    Been there, done that!
    Your pool most likely has an overflow so it won't flood over.
    Most spigots will flow about 6 gpm so you added about 6,000 gallons of water. That's probably about 30% of your pool so it's completely believeble that your salt dropped that much.
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    If you wanna really nice water bill try leaving it on from Saturday afternoon till Wednesday afternoon.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
