Results 1 to 20 of 20
Thread: New to Pools and about to start IG Roman end pool.
    Everyone,
    I'd like to thank you for the contributions and posts about your builds. They have been very helpful sorting through many of the primary decisions that need to be made. It has also created some indecision on my part on a couple important items and would love to hear everyone's thoughts.
    We are pretty set on a roman end pool with a 9' or 10' depth with an 8' diving board
    #1 20 x 40 or 18 x 44?
    Surfaces
    #2 Gunite with Pebbletec or Pebble Sheen or Liner?
    I've read both price and general abrasive ness as downfalls of the Gunite and Pebbletec.
    I've read liners can be ripped, but typically cost plus a replacement or two are about equal to Gunite and pebbletec
    Deck surfaces
    We like not slippery and not too hot to walk on. The rest is cost and appearance. Thoughts?
    Anyone's input with experience on any of the above would be greatly appreciated.
    BQ
    20 x 44 vinyl IG 44,000 gal, Pentair 3hp vs intelliflo, intellichlor and starite heater.
    8 x 10 viking Royal hot tub
    tf100 test kit with k-1000 kit.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: New to Pools and about to start IG Roman end pool.
    Have you looked into Pebble Fina? I adopted a pool with that finish. I have swam in all three Pebble finishes. The Tec and Sheen are a bit abrasive and can be tough on tender skin but they are really attractive and durable.
    Fina is very smooth like old school plaster but it uses crushed marble and quartz to add durability and to give it a little pop.
    Check it out---->Pebble Fina
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I replied to you earlier, but it seems my reply was lost,
    On the topic of diving boards I feel deeper is always better, and longer is always better, in my experience the most common problem is someone making a semi shallow face first dive and clipping the slope coming up to the shallow end. My pool is a 20x40x9 traditional hopper end pool (30+ years old), and feel it is marginal for having a diving board. Simply put most residential pools are too small to safely handle a diving board, I would say an 18x36 would be the bare minimum, that is only if it has an unusually small shallow end, and 8.5 or 9 ft should be the bare minimum depth, with 10+ or 11+ being preferred.
    Ike
    Thanks guys. I saw your other post Isaac, but realized I was in the wrong sub forum...anyway, I am 6'4 and feel the deeper the better for the pool. I also have hit the incline to the shallow end, fortunately not hard enough to injure. So what is that distance from end of diving board that you would recommend. With a 40' pool I figured it wouldn't be an issue ant the purpose of going to a 44' pool was actually to increase the shallow end since the 10' pool depth would drastically effect the length of the shallow end.
    UN...I haven't heard of Pebble Fina but am very interested. It looks great in photos. Now if I can find someone with it to see in person.
    What did you guys do for a pool deck?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    My pool is 18' x 43'. 5' of the length is taking up by stairs. I would suggest getting it as long as possible if you are going to have a diving board.
    Have you considered a diving rock/stone?
    Have you considered making one of your steps in the Roman end large, like a sun deck?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Harley,
    Believe it or not, my insurance company would choose not to cover us if we have a diving rock, but are OK with a diving board. (Opposite of most other insurance companies around here)
    Do you have photos of your pool? I realize it's a sport pool, but the overall footprint is near what I was thinking.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Really hard to get an idea of size but here is the best i have
    18'x43' Sport Pool
    That's great. Thank you. Looks plenty wide for sure. Is that an auto cover as well?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Yes it is, i love it! It is expensive but worth it. Once we determined we wanted one we decided to stick with a rectangle design so that the cover wouldn't have to pull across concrete. People put them on odd shaped pools, butthe tracks then are mounted on the surface of the deck, vs. under coping.
    18'x43' Sport Pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I don't really have a specific suggestion, I can tell you though that on my pool the common danger zone of clipping the slope is centered about the mid point of the pool (so 20 ft from either end, or maybe 2-4 ft closer to the shallow end from the center), and the center point of the pool has just over 5 ft of water.
    Ike
    Quote Originally Posted by harleysilo
    Do you have any close ups of the coping where the track runs?
    Do you feel it saves you the "advertised" savings? Ie Chemicals, water evaporation, heating if applicable?
    BQ
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I posted some in this thread automatic-cover-observations-coverstar-t46899.html
    We bought the cover because we have kids and like the security. Yes you can walk on it, in fact you pretty much have to step out on it to put the cover pump on it in prepartion for rain. You could have a party with 20 of your closest friends on it if you wanted to. The cover will collect the rain water and that has to be kept pumped off. Actually you could leave it on, but you aren't suppossed to open it with water sitting on it (too much weight for motor). If i didn't pump it off eventually it would overflow into the pit and drain from there. It won't damage the cover, it's designed to support that much weight (which is really just resting on the pool's water).
    I agree with all of the manufacture's claims. Yesterday when i got home pool was 96. The cover eliminates a huge %, probably 99, of evaporation. If my chlorine gets a little high my pool stays high for days. Having the cover on while the pool is not in use means almost no debris gets in the pool. I only manually vacumed once last year, and none this year. Once this year, a few weeks ago, my pool water smelled "stinky". pool-water-smells-like-stinky-t65599.html It went away the next day. I think i just need to leave the cover open a little more and it won't happen again.
    18'x43' Sport Pool
    Is it safe to assume that a lighter cover will help keep the pool cooler in the summer as well?
    Update:
    After getting an education on safety covers, and differences on liners vs gunite, we have opted against the safety cover and gunite.
    So it's a vinly liner pool we're going forward with.
    The quotes on the auto cover were around $14,000 which don't justify it's "savings" in my opinion.
    I checked out 2 liner pools done by different companies. One just put a liner over the steel steps with no back fill. The stairs were hard and hollow sounding and even flexed a little. The seams were very noticible as the print had worn away exposing just white vinyl. The pool is only 1 year old.
    The second pool was done by a company that won't serve my area due to distance, however, the stairs were rigid, but soft on the treads.
    The H/O said it was just vermiculite that was used.
    One of the pool builders we are looking at uses a light blue foam pad around the pool.
    Does anyone have any insight on either of these methodologies?
    Thanks a lot for your help.
    Apr 2013
    Sacramento, CA
    2,769
    Your PB should know this already but attached are the national standards for pools with diving boards. They are rather difficult to follow at times.
    http://www.divingboardsafety.net/Standa ... -pools.pdf
    I vote gunite with pebble fina -- durable and looks great.
    Apr 2013
    Sacramento, CA
    2,769
    Couple more references for you:
    Two major slide and diving board manufactures are Interfeab and JR Smith. Their websites are very helpful if you are planning a slide or diving board. I strongly suggest reading the installation manual of the product before you buy it even if your PB is installing it.
    http://www.srsmith.com
    www.interfab.com/?
    Nov 2011
    Moberly,MO
    1,010
    As a builder for a person of your height I would recommend a 6' board. Not anything longer.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Quote Originally Posted by swimcmp
    Why ?
    Nov 2011
    Moberly,MO
    1,010
    The shorter board doesn't put you out over the water as far. A little less chance of hitting the slope going up to shallow.
  20. Back To Top    #20
    That is why I'm going with a 44' long pool. The diving board will be mounted a little further back than the 6' would, but the 8' would give much more bounce.
