Thread: Maximum solar efficiency
    Jun 2008
    Southern Ontario, Canada
    38
    I have (6) 2 x 20 Sungrabber solar panels for my 18 x 36 inground pool.
    I run an independent 3/4 hp pump for the solar system and wondering about efficiency
    of the panels. Should I be installing a diverting valve to reduce flow through the panels?
    I think this is getting into the "Law of diminishing returns" area, but wondering how to maximize
    the heat output.
    I guess I would need to figure out my GPM output?
    Who can help here?
    20 x 40 in-ground concrete
    1 & 1/2 HP hayward pump
    Hayward sand filter
    Aquarite SWG
    Sungrabber Solar Panels
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You will get the most heat out of the panels by maximizing the flow through them.
