Results 1 to 14 of 14
Thread: Finished but just discovered TFP.
    We are finished , but I know you guys love a good DIY. Excuse the appearance of the working men , they all may or may not have been influenced by Bud light.
    Re: Finished but just discovered TFP.
    Wow , I better try harder to put these next photos in order [attachment=2:1qhffm9e]315066_439908406060806_2102430080_n.jpg[/attachment:1qhffm9e] Before concrete [attachment=1:1qhffm9e]524420_440777955973851_804615986_n.jpg[/attachment:1qhffm9e] Upper retaining wall [attachment=0:1qhffm9e]376739_441521032566210_121765998_n.jpg[/attachment:1qhffm9e]
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Looking good !!!
    Jeff
    [attachment=2:1267ct0e]539141_441580019226978_1850785014_n.jpg[/attachment:1267ct0e] [attachment=1:1267ct0e]934954_555368561181456_1811367652_n.jpg[/attachment:1267ct0e] [attachment=0:1267ct0e]425184_568015676583411_1989603293_n.jpg[/attachment:1267ct0e] Kit purchased from National Pool Wholesalers
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ahh now that's what it's all about !!
    Jeff
    and finally , the prized night shots[attachment=2:k699brhc]night 1.jpg[/attachment:k699brhc] [attachment=1:k699brhc]night 2.jpg[/attachment:k699brhc] [attachment=0:k699brhc]night 3.jpg[/attachment:k699brhc]
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Very nice. You should be proud of yourself as I'm sure you are !!!
    Jeff
    May 2013
    Deep East Texas
    79
    Really nice!!!
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
    Butterfly's Avatar
    South Carolina
    10,045
    Fabulous job
    You really should put some water in the pool first!
    You're done SLAMing when:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Nice build and no need to worry about those kinds of appearances. No pool around here could be completed without a "few" cold ones.
    You guys did a really nice job. Hope you stick around now that you found us.
    Essential Links:
    30,414
    That is a vermiculite bottom, right? It may be one of the smoothest installations I recall seeing.....far better than the one I paid for.
    Quote Originally Posted by Butterfly
    Fabulous job
    Haha , I thought the same thing after I took the pic , but the SWG just makes it that darn clear!
    im not exactly sure what vermiculite is , but I can tell you what ours is. Its concrete drypack , just regular sidewalk mix with less water so its like clay instead of smushy cement, you get it set exactly how you want then you just add more water to set it. Then we sanded it with concrete sanders till we got every single imperfection out. In our area they didn't offer gunite or shotcrete and the only PB in town wanted 18k for install not including our mass amount of decking. I wish we would have done a spill over because our marquis stand alone just doesn't ever get messed with now. Our Hayward heater keeps our pool a nice 89 degrees at startup (mid april)
    Mar 2013
    Southlake, TX
    114
    Really nice outcome! Thanks for sharing.
    19' x 37' Freeform IG; 25,500 gallons; max depth 8'6" with diving board; sun bench and swim out shelf. PebbleSheen Blue Granite Finish; Noble Tile--NVSA616 Peacock; Sandstone Retaining Wall; Oklahoma Flagstone Coping, Aggregate Deck; Small Water Feature w/ Moss Rock (70% flats and 30% boulders) Jandy Stealth 2HP Pump and CV460 Filter; AquaCal SQ156 Heat Pump/Chiller; Polaris 380 pressure cleaner w/ Halcyon boost pump.
