Results 1 to 7 of 7
Thread: Incorrect Pool Volume For 4 Years!
    Alynn's Avatar
    Jun 2010
    Jacksonville, FL
    52
    I was just reading the manual on my Pool Pilot Digital Nano (again.....) and saw where the the installer programs the pool volume. I seem to be having trouble with the SWCG maintaining the chlorine. I've been running it at 100% 9 hours a day....
    So I double checked the programmed pool volume, it was set at 15,000 gallons. Now I have a irregular, free form, sort of kidney + shaped pool, wide at both ends, more narrow in the middle and was told by the pool renovator that it was approximately 22,000 gallons.
    I've just measured it again, averaging the wide ends with the narrow middle to get an average width of 19' by 38' long. It is 8' at the deep end and 3' at the shallow end. According to the pool calculator, my volume is 29,700 gallons. WTH?????
    If this is correct, then I have been way off on EVERYTHING! No wonder I can't keep the algae at bay for very long! Ugggggghh!!!!!!!
    Have I correctly figured the volume of my pool? If so, I'm sure that you will all agree, I need to readjust all my calculations, as well as resetting the SWCG.
    Here is a photo of my pool. It's the best I could do without climbing on the roof, and I'm just too darn tired for that tonight!
    [attachment=0:2qwwfrkv]ImageUploadedByTapatalk1374102824.735076.jpg[/attachment:2qwwfrkv]
    Any advice will be appreciated. Commiseration allowed, as well.
    Alynn
    22,000 (OR NOT?) Gallon In Ground with CrystalStone (pebble) finish in Blue Ice
    Pool Pilot Digital Nano SWG
    Pentair 1.0 HP Pump
    Hayward C1200 (120 S.Ft.) Cartridge Filter
    Pentair Great White Automatic Pool Cleaner
    22,000 Gallon In Ground with CrystalStone (pebble) finish in Blue Ice
    Pentair 1.0 HP Pump
    TF-100 Test Kit
    Aug 2011
    Clarks Summit,Pa.
    37
    Re: Incorrect Pool Volume For 4 Years!
    I would measure it in 2 separate sections,(using the pool calculator) just do the deep part up to where it is at the narrowest point, and then do the shallow end which by the picture it appears wider than the deeper end, now add both of them together and that should be close.
    12,000 gal. 14x28 Inground vinyl liner (2004), 1 HP. Jacuzzi magnum pump,
    Raypak heater, Jacuzzi laser sand filter,Autopilot DIG-220 SWG, 35/22 cell,
    TF-100 test kit,K-1766 saltwater test kit, speedstir
    Jul 2011
    Arizona & California
    805
    The following link might help you determine and/or confirm the volume of your pool. a-chemical-way-of-calculating-pool-volume-t66473.html
    Just looking at the picture, using the chairs as a reference, that pool looks a lot closer to 15k than 22k.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    38,415
    That sure looks smaller than my pool which is 18k
    What did you use for an average depth?
    Alynn's Avatar
    Jun 2010
    Jacksonville, FL
    52
    Hey all! Sorry about my panicked post last night. I've become frustrated with dealing with my small algae outbreaks, and was researching anything that would be off, keeping me from keeping the pool balanced.
    I found a website that helps with measuring a free form pool more accurately, so I remeasured (in a much calmer state of mind, I might add!). I measured the same way as I did yesterday, and my numbers were somewhat different.
    It looks like my pool builder was about right. I came up with just under 22,000 gallons. I did, however reset the SWCG pool volume, as it was only set to 15,000 gallons.
    The length is 33', the average width is 16 and the average depth is 5.5. (3' shallow and 8' deep).
    I added about 3.5 gallons of 10.5% liquid chlorine last night. Pool water is crystal clear with 2 spots (about 1' X 3' each) of algae on the wall.
    Current test results:
    FC: 17 (added 3.5 gallons last night.)
    CC: .05
    TA: 130 (high)
    ph: 7.8 (a little high)
    CH: 300
    CYA: 60 (added 48 oz. Monday night after letting out about 5 inches of water from thunderstorm. I added it before there was any visible algae).
    I will be adjusting the ph this weekend, and it looks like I'll be SLAMing against this weekend, as well. Although, I hate to think about how much chlorine it will take, as I've added the CYA to bring it to about 75.
    Any and all suggestions are welcomed! And thanks for all the help!
    Even with my algae outbreaks, it still is a whole lot better than the brown swampy mess that was in my backyard when I bought the house in 2009!!!!!!
    Alynn
    Pentair 1.0 HP Pump
    Pentair 1.0 HP Pump
    TF-100 Test Kit
    38,415
    I think your average depth is likely lower because the deep end looks smaller than the shallow end and the deep ends are usually more curved on the bottom. Did you actually measure the depth?
    Sounds like you are on the right path. You could sort of check the volume by measuring the FC, using the calulator for a target, and then testing again in an hour to see if you hit the target. If you are always high on the FC, that could mean the volume is less ... or it could mean that the bleach was stronger, so it is certainly not exact.
