Thread: Spa Drain/Polaris Return
    So, I'm a new pool owner and am having trouble figuring out how to circulate water only in the spa portion of my pool. I have shut off the return valve to the main part of the pool and left open the spa return. Then, shut off the skimmers and main drain and opened the spa drain. The water level starts to go down at that point. I have realized that water is still leaving the spa because the return that my Polaris cleaner is hooked up to splits off before the point on the plumbing that splits the main returns and the spa returns. Make sense????? There is no valve on the Polaris tube that goes to the Polaris booster that makes the robot work. (At least no valve that looks like the rest of my valves.) Any ideas????
    Newer Pool Owner / old pool (my 3rd season, pool's 29th)
    Hayward EC65 DE filter
    Hayward 1 HP Super Pump
    16 x 32 Wilkes vinyl pool semi-AG (partially buried - 8' hopper deep end) with deck. Bottom drain and skimmer on side, pipes are buried.
    Welcome to TFP!
    You need to turn off the return going to the Polaris or it won't work. If this is a new pool, have the builder come and either show you where the valve you can't find is or put in the correct valve if there isn't one already.
