Results 1 to 14 of 14
Thread: heat wave in ontario canada
    been dumping water out the past 3 days pool is at 90 f
    solar blanket off
    would it be better to leave it on during the day
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,595
    Re: heat wave in ontario canada
    It would be better to aerate the pool at night to reduce water temps. And 90 is a good day in Texas!
    thx been running the pump 24/7 right now need to get something to aerate with
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Improvise a way to return water to the pool from above the pool walls, this will create enough splashing to increase evaporation cooling.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You can get amazing results if your contraption sprays water up into the air and let's it fall like rain onto the surface. When i run mine the "rain" has lost 10 degrees by the time it reaches the pool. I can lower my pool temp several degrees in one hour of running, during the day when it's sunny and 90. After several designs i like this best as my delivery....
    Here is a video of one of mine running
    You could make it a little smaller if you made it not adjustable.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    I bought a fountain, sends to help but the volume of water is too small too make a difference. I like your design! What size PVC?
    21' AG (~11,000 gallons)
    Hayward S180T sand filter (35 gpm)
    Hayward Power-Flow SP1510 pump
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Mine is 1.5" PVC mainly because that is what my returns are, so it can screw right in...However the piece that transitions from PVC to the garden spray nozzle necks it down to like 1/2".
    I have two of those, one mounted on each of my returns, so all my water is going through 4 of those heads. When it is on the pressure on my filter rises by 2, so i am somewhat restricting flow.
    I tried getting a really small drill bit and drilling a ton of holes in a length of PVC first, could never get the rain effect that these heads provide however. Plus the larger streams of water created a bunch of noise, that isn't necessary. These aren't intended to vigorously aerate the pool, just cool it.
    18'x43' Sport Pool
    Ya I am in Ontario too and this is nuts. We have a salt water above ground pool so we don't chance it, we run our filter and pump 24/7 and have never had a problem. I do notice the chlorine dropping with this weather so I will have to turn the chlorinator up a little each day till I can start getting better readings. Been keeping the solar blanket off for sure or I think the water would start boiling lol. Pool is at 90 to 91 the last few days. With this heat it almost is not that refreshing anymore. From what I hear only a few more days of this then we should be into some better weather next week.
    On ground pool 16x32 with deep end -shallow end 4' deep end 7' 80 000L of water pool installed 2011 SW (currently not working) sand filter we are in ontario
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Quote Originally Posted by woodyp
    With humidex it is well it is well over 100... Yesterday was 32 Celsius and felt like 42. Not sure on how to convert it. Isn't the heat in Texas more dry than here? Kinda like Vegas heat.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    When there is high humidity, the human body cannot use its own evaporative cooling system so efficiently, so it feels hotter than it really is.
    Same principle applies to what we try to do to the pool water, we try to increase evaporation by returning water from above and having as many small jets of water as possible to increase evaporation even further, as evaporation needs energy that comes from the body of water, thus lowering the temperature of the remaining liquid.
    Where's that heat now? Feels more like fall here in Ontario than Summer.
    My pool is to cold to even swim in now.
    thx for the help wish i could have bottled the heat i wanted to get rid of pool has now been to cool to swim since than looks like next week will warm it up
    Oct 2012
    Houston, TX
    186
    Quote Originally Posted by topher
    West Texas is the most dry part, but it isn't Vegas or Arizona dry. Still, that is 9-10 hours drive away from the Houston area. The Panhandle is also more dry than here. Pretty much, if you exclude the panhandle... split the state in half north to south and everything east of the line is pretty humid.
    Most of the summer here in Houston is what you are experiencing. It's typically 33-38c actual temp and 41-42c heat index (factored for humidity) when high pressure prevails, as it is now. When low pressure prevails the humidity rises even more and the differential increases... typically actual temp goes down a bit but heat index stays the same, due to higher humidity. However, this isn't considered a heat wave. It's normal. We haven't had a heat wave yet this year.
    My water has held steady at 88-89f (31.5c) all month and it feels quite refreshing, especially after doing any activity outdoors. It's all perspective I suppose.
    I also have an 11' cantilever umbrella over the pool when it's this hot. as the sun moves, probably 1/4-1/3 of the pool is shaded at any point during the day. It help for sure! You might try this as well. If nothing else, I like that it provides a spot of shade to hide from the blaring sun while in the pool. That helps too.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Aug 2009
    SW Wisconsin
    518
    Wow..wish we had your "problems" here in the upper midwest...It's been so cool all summer, our tomatos have yet to turn red, and the rest of our garden is very far behind where it normally. is....I don't even want to TALK about our pool. We have a large above ground that only see's maybe 7 hours of sunlight a day, because of the tree's around it..and the highest our pool temp has been ALL summer is 80F. Our temps during the day have been under 80F and at night our temps dip down below 60F...unheard of for summertime temps. We do have a pool heater, but it would KILL our budget at this point to try and run it enough to keep our pool at 85F right now. It may be an early pool closing this year!
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
