Results 1 to 12 of 12
Thread: curious about price of stamped concrete
    We are realizing the 400 sq feet the builder provides is not enough decking. We were quoted 8 sq foot for stamped concrete. Does that sound about right? We are looking at 300 extra square feet...ouch.
    30k Gallon in-ground, Vinyl, Loop-Loc cover, Hayward Super Pump, Hayward s-200 sand filter, Dolphin supreme m5, TF100 Test Kit, Speed Stir
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Re: curious about price of stamped concrete
    Is that the total? We are paying $6.5/sqft for the concrete pour and $4.5/sqft for a stamped overlay (I believe it's similar to Kool deck) so in total $11/sqft.
    The decking cost is the largest single add on to my pool.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by momoffourbabes
    They are charging 13-16 here. Sundek/Kooldek (Acrylic) deck is running about 7.75-9.00 a square with all three builders we have talked too.
    Essential Links:
    Plumbing is our biggest cost. We have to run a gas line 100 feet (and electrical as well).
    Killer95Stang's Avatar
    Sunny SoCal
    592
    $8.00 per sq ft is a pretty good deal for colored and stamped. Here in CA it averages around $10
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    May 2013
    North East Ohio
    959
    Yep, just had my poured and $8 per sq ft is a great deal....assuming of course the prep is correct. (I paid nearly $11)
    If using fill, it must sit for a long time (3-4 months IMHO) to minimize shifting.
    Then 4" stone compacted
    Then rebar/mesh
    Then 4" concrete
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Sunny SoCal
    592
    Quote Originally Posted by toofast
    How many people are going to wait 4 months after the pool is done to pour the deck? They build skyscrapers in shorter periods of time.
    May 2013
    North East Ohio
    959
    Quote Originally Posted by Killer95Stang
    Yes, I agree - but they are using different construction techniques to ensure no settling...like driving pylons hundreds of feet into the ground.
    My point is many people backfill, then pour a deck the next week...that is generally asking for trouble. Four months may be long, but the point is 1 week or 2 is really not enough.
    Dec 2009
    Central Massachusetts
    2,690
    How many people are going to wait 4 months after the pool is done to pour the deck? They build skyscrapers in shorter periods of time.[/quote]
    I went 8 months. But then again 6 of those months were winter and the pool was closed. I wouldnt even think of pouring a concrete deck for at least 3-4 months after the pool was built.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Apr 2013
    174
    $8 is a good deal. I couldn't get that low for a stamped pattern even after some negotiation.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Apr 2013
    DFW, TX
    72
    ~$8/ft in DFW area.
    Jun 2013
    Huffman Tx
    190
    I paid 4sqft for the concrete deck and 1.25sqft. for kool deck . the kind they fling on with a brush then go over with flat blade , However they did a crappy job with the coating pattern and it ponds alittle
