Thread: Beaded Liner Came Out
    Jul 2007
    Hillsborough, NC
    525
    Pool party this afternoon - 8 kids in the pool. At one point about 4' of the liner came out of the bead. Is this something I need to be concerned about? How to prevent this in future? I did not lose any water. I took the top rails off and pushed it back into the bead. Of course now that this happened I will worry about it happening again from now on.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Beaded Liner Came Out
    Typically you do not need to take the top rail off to put back a liner bead into a bead receiver. I have heard of something called "bead lock" that also goes in the bead receiver along with the liner bead and helps keep it in there.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    We have the bead lock on our pool. I have no idea where to get it as our installer had it with him.
    BUT I have heard of people using pennies and Popsicle sticks. All you really need is something to fill in the space where the liner goes in the holder. Good luck!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Maybe some of that round rubber stuff of the right diameter they use on screen windows?
    DonW's Avatar
    Jun 2008
    Central IL.
    96
    Happened to me too except it had happened over the winter and was found out after the winter cover came off. Get this: http://www.inyopools.com/Products/03800 ... 4Aod7FMAXg
    I just put it on our pool and it took around 4 hours as I had to remove all the top rails to be comfortable with the install. Will it work? Won't know until the next time, or lack of next time. I posted earlier on if anyone had success with the liner lock and never got a conclusive answer. I can tell you this though, that for $30 I "feel" a little more confident that it won't happen again.
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    When mine came out I put pennies in the bead with the liner still in place a few years later
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
